how you you verify cam specs?
Old Oct 17, 2004 | 12:03 PM
mos90's Avatar
mos90
Default how you you verify cam specs?
i bought a good used zz409 cam. from what i see it is a small base circle cam. what is the best way to verify the lift and duration of this cam once installed in the car. i tried to measure the valve open and closed to get total lift but a didnt have a mic and the lifters didnt have pressure built up yet, so i got false reading. it is really hard to eyeball a cam and see lift differences. is there an easier way?
Old Oct 17, 2004 | 12:20 PM
CFI-EFI's Avatar
CFI-EFI
Degree it. You will need a piston stop, dial indicater and a degree wheel. All the cam manufacturers have the proceedure in their catalogs, but it is pretty untuitive.
RACE ON!!!
Old Oct 17, 2004 | 02:40 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You need the proper tools to degree a cam as well as to check its specs.
If you know the cam specs, you can get the procedure from Comp. Cams site.
Old Oct 17, 2004 | 02:49 PM
mos90's Avatar
mos90
the reason i was asking was that i didnt think the lift was as much as the stock cam, but the lobes are much steeper and definatly has more overlap. the fact that it is a small base circle cam might make just looking at the lift not very accurate. i just hate to get everythingput together and find out it is the wrong cam. i know the tpis part # is engraved in the front, so it is probably the right one. maybe im a little paraniod.
Old Oct 17, 2004 | 04:03 PM
65Z01's Avatar
65Z01
Well, you could just measure the base circle of each and you would know how much more lift the TPIS has.
The lobe peaks must be the same heght to clear the bearing holes, right, so more lift comes from a smaller dia base circle. A pair of calipers (not expensive from Sears) will be accurate enough.
Old Oct 17, 2004 | 04:24 PM
CFI-EFI's Avatar
CFI-EFI
Degreeing the cam is a good idea whether you have suspicions or not. It verifies your work and that there isn't a stack up of tolerances that put it "off the mark". You don't have to wait until, "everythingput together", to check it. All you have to install is the cam, lifters, and timing set. Then if you find anything not to your liking, you are at the prefect place to rectify it.
RACE ON!!!
Old Oct 17, 2004 | 08:39 PM
mos90's Avatar
mos90
RACE ON!!!
seems like a good idea. i will pick up a degree kit tomarrow and check it out.
Old Oct 18, 2004 | 12:37 PM
JAKE's Avatar
JAKE
Many of the machine shops that specialize in racing engines have computerized camshaft checkers. They can spin it up and give you all the data on the cam.
I had a ZZ9 done at Dennis Wells" Racing for $25
Jake
Old Oct 18, 2004 | 01:47 PM
Red Tornado's Avatar
Red Tornado
What JAKE said is another alternative. I had mine checked on a "Cam Doctor", for about the same price.
Old Oct 18, 2004 | 01:48 PM
mos90's Avatar
mos90
the only thing with degreeing the cam is you will find out what is it is installed at but it wont tell you specs of the cam.
Old Oct 18, 2004 | 02:23 PM
CFI-EFI's Avatar
CFI-EFI
What spec could you possibly hope for that you can't ascertain with the degree in process?
RACE ON!!!
Old Oct 18, 2004 | 03:05 PM
Red Tornado
i'm sure he also just wants to verify the advertised vs. actual specs.
Old Oct 18, 2004 | 05:42 PM
mos90's Avatar
mos90
yes...you cant verify lift and duration with degreeing as far as i was told..
Old Oct 18, 2004 | 06:38 PM
65Z01's Avatar
65Z01
Since the engine is in the car you may need to fab up a smaller degree wheel. Then a dial indicator is all you will need to spec out the cam.
Can you use a square rod in a drill through the dist opening spin up the oil pump to lube the lifters or is it an LT1? Are you trying to measure lift at the tip of the push rod with the rocker off?
Old Oct 18, 2004 | 06:47 PM
CFI-EFI's Avatar
CFI-EFI
Why not? What do you guess "degreeing" IS? Why can't you check anything and everything? Have you looked at the instructions for degreeing in a cam?
RACE ON!!!
To how you you verify cam specs?
