Average cost of 3" catback?
Old Oct 17, 2004 | 04:54 PM
GlockLT4's Avatar
GlockLT4
Default Average cost of 3" catback?
What price should I be looking to pay for a 3" custom cat back?
I have a set of longtube headers ready to put on my car, but I'm going to need someone to create a custom 3" catback. Best quote i've gotten so far is $1100. I know if I brought $99 high flow cats to someone that they should be able to do this for like $600 if the headers are already on.
Thinking of magnaflow mufflers.
Old Oct 17, 2004 | 05:22 PM
JB666's Avatar
JB666
Ouch! $1100?? My custom shop, locally quoted me $700 IF I SUPPLIED THE MUFFLERS, $900 with them supplying.
I went with Corsa. I figured the build quality would be A+ either way.
So you have the stock cats on now? Is this $1100 including hi-flow cats??
Old Oct 17, 2004 | 05:24 PM
chriswtx's Avatar
chriswtx
The best way to do this is buy the B&B 3" system($899) and specify the x-pipe, buy 2 3" bullet cats, and 4 3" band clamps. Cut the flanges off the headers and the B&B system with a reciprocating saw. Then it is a nice, clean bolt in job you can do yourself. The money you save on labor you can use to buy the stainless cat back B&B. It took me about 2 hours to do it on my car without cats. I can send you some pics. Shoot me your email...
Old Oct 17, 2004 | 05:54 PM
chriswtx's Avatar
chriswtx
Here is a group purchase going on for the B&B 3" for $849.
http://forums.corvetteforum.com/showthread.php?t=918049
Old Oct 17, 2004 | 06:01 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
3 inch B&B w/x-pipe, no cats, EM full length headers
Old Oct 17, 2004 | 06:06 PM
tjwong's Avatar
tjwong
Its a peice of cake to connect the EM and TPIS headers to a B&B 3" system.
Check it out in my picture above.
All you have to do is to extend the pipes to the header collectors. One side is like 6" and the other is like 11", have a exhaust shop swage the ends to slip over your pipes and to the collectors. Thats basically all there is to it, I welded mine to the B&B side and to the collectors is a slip fit with a HD band clamp.
Old Oct 17, 2004 | 06:35 PM
James94LT1's Avatar
James94LT1
Those clamps are much nicer than the u clamps my exhaust shop uses. Where could I find some "Hd band clamps"???
Old Oct 17, 2004 | 06:51 PM
chriswtx's Avatar
chriswtx
Summit or Jegs carries band clamps
Old Oct 17, 2004 | 07:22 PM
James94LT1's Avatar
James94LT1
Cool! Thanks!!!
Old Oct 17, 2004 | 08:47 PM
smokiethegreat's Avatar
smokiethegreat
i just had a shop i used to work at do a sys for my 85. from the manifolds into a custom y-pipe through a good 3" cat back into another y out to flowmaster mufflers with stainless tips. cost around 700-750. my cost was much less since they have been good friends since childhood. I did the single 3" cat and center pipe for immission reasons(factory had single cat) it looks and sounds great. but the trip out to utah might negate the price. thats my only knowledge in pricing.
in my experience flowmaster mufflers perform,sound, and last the best.
Old Oct 18, 2004 | 09:18 PM
GlockLT4's Avatar
GlockLT4
I'm not so sure about cutting the flanges off of the headers.... I have enough exhaust leaks as it is and that would be a good source of more if it doesn't fit exactly right.
And I have to have cats due to emissions here.
How is resonance inside with the B&B with X-pipe?
To Average cost of 3" catback?
