Proper engine break-in
Old Oct 17, 2004 | 05:44 PM
95_6spdvette's Avatar
95_6spdvette
Default Proper engine break-in
Hey guys, I just got another LT1 motor put in my car and was wondering if there was any certain break-in method to extracting more performance out of it. How should I drive it for how long before i can start running it hard? Your helps appreciated
Old Oct 17, 2004 | 06:14 PM
Lone Ranger's Avatar
Lone Ranger
Old Oct 17, 2004 | 07:56 PM
Dan Parker '96's Avatar
Dan Parker '96
Build it. Get it up to temp. Check for leaks and any obvious problems.
Then run it like you stole it.
The naysayers are pussies.
Old Oct 17, 2004 | 08:08 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
After building mine, this is how I broke it in. After running it in the garage long enough to verify that all systems were go, I took it out and made repeated runs in second gear (automatic) up to 5,000 rpm and then immediately backed off letting the engine decelerate the car back down to 15-20 mph and then repeated. About 15-20 times of this and your rings will be seated as well as they can be. Then just drove it normally and changed the oil at 150 miles and again at 1250 miles. Within a couple hundred miles of initial break-in, I was running it to redline. My clearances are by design, a little looser than stock. If yours are not, maybe wait until after that second change to run all out. I broke it in on Mobil dino oil and went back to synthetic at the 1250 mile mark. Nearly 6,000 miles on it now with no oil consumption at all and no problems.
Old Oct 17, 2004 | 08:11 PM
smokiethegreat's Avatar
smokiethegreat
the best way that i know of is to run some good non-synthetic oil in it for 500 miles and then change the oil and put a good synthetic oil in it. the theory on the non-synthetic oil is that the synthetic oil doesnt alow the piston rings to seat as well/fast.
I've also known of those who start it up, get it to temp, check for leaks and then go out for a good hard run.
as for me i like the first way best, those i know who have done it that way have run better that those who dont.
The best thing i can tell you to do is just what you are dooing. gather up as many opinions as possible and decide from that.
Old Oct 17, 2004 | 08:21 PM
fa63's Avatar
fa63
I agree. Today's modern engines do not require traditional break-in prodecures due to advances in CNC machining and such.
Old Oct 17, 2004 | 08:27 PM
Ghostpilot's Avatar
Ghostpilot
Break it in like your gonna drive it. Hard and fast
Old Oct 17, 2004 | 08:28 PM
chriswtx's Avatar
chriswtx
To add to this "After building mine, this is how I broke it in. After running it in the garage long enough to verify that all systems were go, I took it out and made repeated runs in second gear (automatic) up to 5,000 rpm and then immediately backed off letting the engine decelerate the car back down to 15-20 mph and then repeated. About 15-20 times of this and your rings will be seated as well as they can be. Then just drove it normally and changed the oil at 150 miles and again at 1250 miles. Within a couple hundred miles of initial break-in, I was running it to redline. My clearances are by design, a little looser than stock. If yours are not, maybe wait until after that second change to run all out. I broke it in on Mobil dino oil and went back to synthetic at the 1250 mile mark. Nearly 6,000 miles on it now with no oil consumption at all and no problems."
I would also change the oil after the first run in. The assembly lubes that are used to put the engine together need to come out as soon as possible. After the first 30 mins. of running I drained my oil and it was nasty. The breakin is incredibly hard on oil. Turns it into "water" it breaks it down very fast.
Old Oct 17, 2004 | 08:33 PM
James94LT1's Avatar
James94LT1
If its gonna break I want to be close to home, so back it out of the drive way and hammer it!!! I alos agree with using reg. oil for breakin, I too have heard it helps seating but also its only going to be in there for a very shot amount of time so its also cost effective!
Old Oct 17, 2004 | 11:08 PM
Unity's Avatar
Unity
Old Oct 17, 2004 | 11:47 PM
Corvette Kid
While that certainly wouldn't hurt anything, the only assembly lube I use is Lubriplate #105 and it's perfectly compatible with engine oil. If this had not been a high performance engine, I'd have probably gone at least a 1,000 miles to the first change. The HD diesels I build for a living go right out on the road and go to their normal 12 to 15,000 mile interval before changing. With proper care, these engines will often go a million miles or more and with a 10 gallon or so oil capacity, changing oil in them unnecessarily is an expensive proposition. And with these engines putting out 500 to 600 HP and up to 2,000 lbs. ft. of torque these days, I doubt that other than all out race engines you'll find a tougher test of lubricants. When I changed mine at 150 and 1250 my magnetic plug showed only a trace of gray dust and I'd have put the oil I drained out into an older car without worry. It was only slightly darker than new.
Old Oct 18, 2004 | 12:00 PM
jimbomill's Avatar
jimbomill
Why would synthetic oil preclude proper ring seating? I would think that it could enhance that.
Old Oct 18, 2004 | 12:02 PM
jimbomill's Avatar
jimbomill
OK - that's a good reason to use non-synthetic, knowing that it will be changed quickly. I mean. if synthetic is slicker, so to speak, it should help seat quicker, all other things being equal.
Old Oct 18, 2004 | 12:06 PM
aeronautica86's Avatar
aeronautica86
so say because it lubricates too well
Old Oct 18, 2004 | 12:28 PM
MR.KIDD's Avatar
MR.KIDD
To my understanding alot of new cars come with synthetic oil in them so if it is a ring seating issue why is GM and others using it with no ring seating problems,or am I missing something.
Old Oct 18, 2004 | 12:45 PM
comp's Avatar
comp
if it's a roller cam
Old Oct 18, 2004 | 01:39 PM
FD2BLK's Avatar
FD2BLK
And so the synthetic debate rages on. About two years ago there was a long debate on here about using synthetic oil for break in so I did a little research and posted the phone numbers and points of contacts I had spoken with at the time. Here was the skinny both Comp Cams and Mobil 1 did not recoment synthetic for break in. If you are sure your machinist has honed the cylinders the same way GM does to seat the rings (Actualy the cyl walls but thats a diferent debate) then you should be fine but if not I would recomend breaking motor in the way the manufactures say with non-synth oil. Two parts make me feel this way 1. The maker of the oil recomended by GM (Mobil One) says NOT to use sythetic for break in and Comp, the maker of the cam I am using, makes the same statment.
Old Oct 18, 2004 | 02:12 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
I say they are like kids. Teach them early what you expect.
I started mine, ran it home, brought it back to the dealership (8miles). Checked it for leaks etc, changed the oil - Took it to the dragstrip.
Corky started his, changed the oil, and took it to the strip.
Do not move to synthetic for at least 1000 miles.
To Proper engine break-in
