I finished
Old Oct 17, 2004 | 10:52 PM
mitchcole's Avatar
mitchcole
Default I finished
This has to be a new record. I started on 9/20/04 and finished today 10/17/04.
Replaced the following pieces:
Spark plug wires
Opti (with dynaspark)
water pump (with meziere)
timing cover gasket & oil seals
welded closed the water pump drive hole in the timing cover
replaced the oil pan gasket
replaced the O2 sensors
replaced the tranny fluid (ZF 6 speed)
Changed the oil
Changed the coolant.
I know waaaay more than I used to about this engine.
I'd like to thank all of you who have helped over the last month - especially Tom Strickland for that wonderful tech tip on this job.
Old Oct 17, 2004 | 10:58 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Just in time for winter
Old Oct 17, 2004 | 10:59 PM
bogus's Avatar
bogus
cool!
Old Oct 17, 2004 | 11:03 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Feels good when you do it yourself, doesn't it?
Old Oct 17, 2004 | 11:52 PM
scofolo's Avatar
scofolo
I wish I knew what I was doing. It would save be a bunch of money.
Old Oct 18, 2004 | 12:08 AM
Perfusion's Avatar
Perfusion
Nice work!
Just curious - what's the reasoning behind welding closed the water pump drive hole? TIA.
Old Oct 18, 2004 | 12:23 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by Perfusion
Nice work!
Just another way of plugging the hole when you eliminate the water pump drive during an electric water pump conversion. I plugged mine with a half dollar and JB Weld. Back side of the coin showing because I didn't want a Democrat's face on my engine!
Tom is very meticulous and if you ever see his car, it shows! Great guy and a bunch of fun too.
Old Oct 18, 2004 | 06:52 AM
mitchcole's Avatar
mitchcole
Winter's not too bad here in California...
I do my own work because I can't really afford this car. I figured with the free labor - I can buy more/better parts.
I like the 50 cent piece idea - would have been cheaper.
Old Oct 18, 2004 | 06:58 AM
Steel Blue 91's Avatar
Steel Blue 91
Needed a good laugh first thing this morning. Thanks!
Old Oct 18, 2004 | 09:15 AM
Ghostpilot's Avatar
Ghostpilot
Now that's good!
Old Oct 18, 2004 | 09:23 AM
comp's Avatar
comp
To I finished
