Throttlebody-to-plenum bolts????
Old Oct 18, 2004 | 01:45 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Throttlebody-to-plenum bolts????
Does anyone remember the size of these bolts off hand. If I recall they are either 8mm or 10mm X 75. I'm installing a Nitrous fogger plate and I will need longer bolts (can't find my old ones to match the size). Also regular hex head bolts won't work with my BBK TB, I will need allen head bolts for the clearance. Anyone know a place to order them from? I am thinking I will need a 90mm bolt to compensate for the fogger plate.
Old Oct 18, 2004 | 08:06 PM
CFI-EFI's Avatar
CFI-EFI
Sorry to be so late. My parts book calls for "M8x1.25x70", for 1985 through 1989. It lists the size in parenthesis. Before it has, "Hfh" and after, "9.8 Por". It looks like this, "Hfh(M8x1.25x70)Por". I have had good luck with nuts and bolts at Lowe's Home Centers.
RACE ON!!!
Old Oct 18, 2004 | 08:18 PM
Wayne88's Avatar
Wayne88
I needed to run a tap on my '88 plenum, the size was 8mm-1.25mm.
Old Oct 19, 2004 | 12:17 AM
NUckINg FuTS
Alright thanks! Help greatly appreciated
Old Oct 19, 2004 | 12:22 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yup, M8x70mm, 1.25mm thread pitch. 10mm hex flange head, partially threaded.
I've got all the bolt sizes for the TPI memorized, after piecing together boltkits.
To Throttlebody-to-plenum bolts????
