free dinner if solved!
Good luck, don't give up.
Also, allow me to introduce you to the enter key... A very useful device when explaining a complex problem.
PHONE CONSULTATION
After Gordon retired from GM's Corvette plant's Action Center, where he told GM's Tech Center and Dealers how to fix the Corvettes, he started For Your Car, Inc. to help the Corvette owners and shop technicians solve their troubleshooting problems by calling him on his consulting line 1-800-39-83883 (800-For Your VETTE). His fee is $10.00 per call, plus $3.00 per minute, while you talk with him. It is charged to your Visa or MC that you supply when you call. He wants to help you solve your problem ASAP and save you money
because you car is not getting enough fuel at idle!!!!!!!!! and for it to stay on you have to give it more fuel.
lets start with most likely to less likely!
1. start with checking the fuel pump make sure it works 100%
2. o2 sensors!!!
3. then check all the fuses!
4 check the ingintion wires/spark plugs to make sure they work.
5. pke system
6. grounds on the car hooked up.
the dash doesnt matter!! that jsut shows you wants going on with the car...has nothing to do with how it runs.
It sounds to me that you have a problem in the serial bus wiring between the CCM and the PCM or ECM. Those would be the first places for me to check out. Tell your guy to isolate the serial communications circuits. Bypass them direct if necessary with a known good connection that way you can at least eliminate any problems with communications between the devices. Also check the fuel enable circuit between the CCM and the ECM or PCM.
I also have a '92 and I'm dealing with a similar issue, although not nearly as severe. My car died once in traffic. After about a minute, the car restarted and ran fine all the way home, but with the Service ASR light on. I got a code 62, which is a tach pulse code fault. Basically, the signal from the ignition system to the EBCM (brake computer) was interupted. The factory service manual states that a short to ground on the ignition side of the tach filter will set a code 62 and cause a no-run condition. Shorts between the tach filter and the EBCM can cause the car to run poorly.
I performed a cursory check of the wiring between the coil/ignition module and the tach filter and didn't see any problems. I'm going to unwrap the wires and check them more carefully, but if they look ok then I plan to replace the tach filter and the ignition module. The tach filter is available from Ecklers for $40, and the ignition module is $100. Either of these parts can fail and cause the problem.
That's where I'd start if I were you. I bet your problem is in the tach pulse circuit. Check the wiring between the coil/ignition module and tach filter very carefully. This stuff is at the front of the engine on the passenger side. The tach filter is a small square black box in the wiring harness. If the wiring looks ok, I'd replace both of those parts before I started ripping out dash wiring. Also, I don't know how you're "bypassing" things, but with the way the computer systems are integrated that's likely to cause more problems than it will solve.
If none of this works (or you can do it first), calling Gordon Killbrew is good advice. Good luck!
First, disconnect the C68 climate control computer (if you have one) and the ASR/ABS computer connections -- the vehicle will run without these computers temporarily. By disconnecting these computers, the only ones left are the CCM and the ECM on the serial bus. Ignore any ASR, ABS, or climate control flashing trouble lights -- they are now disconnected.
If there are no problems after disconnecting those two computers, connect them back one at a time until you find the problem.
If the problem still exists after disconnecting those two, you probably have:
1) An intermttent short on the serial bus -- disconnect all the computers (ASR/ABS, C68 climate control, ECM, and CCM) and put an ohmmeter on the serial bus and wiggle the wires to see if it is grounded.
2) An intermittent problem in the ECM -- if your vehicle is earlier than a '94, this is my guess as to the problem.
3) An intermittent problem with the CCM -- the CCM is pretty reliable and it would be unusual, but not impossible, for it to be the problem.
The thing to keep in mind is there is an encripted security code "handshake", via the serial bus, between the CCM and the ECM at startup. The CCM is responsible for verifying the ignition key "pellet" resistance and telling the ECM that it is valid -- this is where the handshake takes place. If the handshake fails, the engine won't start.
Also, the CCM is the master computer and the rest are slaves -- the CCM is in control of the communications on the serial bus.
If you decide to guess and replace something and your car is earlier than a '94, I suggest the ECM because it is frequently the problem -- but, I don't encourage guessing.
And, if you still can't find the problem, contact Chris Petris -- he writes technical articles for Corvette Fever magazine. He's good at these computer problems.
Tom Piper
2. o2 sensors!!!
5. pke system
I had traded out my ECM, ignition module etc... I even took it to a local Chevy dealer and they couldn't figure it out.
For what it's worth.
Once the engine is started, the ECM should be able to keep the engine running by itself -- if the CCM looses communications with the ECM after the engine is running, the "SYS" will flash, the "Securtiy" light will come on, and the ASR light will come on, but the engine should run fine until the next time you try to start it. Since you are saying the engine does not run fine once it is running, I would look at the ECM, wiring and power to the ECM, etc. Even though the CCM is the master computer, once the engine is running, the ECM should be able to run the engine standalone.
This suggests a ground or power problem to the ECM or a defective ECM.
Plus, since you are loosing communications between the Tech2 and the serial bus at the same time the ECM can't keep the car running, this suggests that power has failed to the CCM too.
Check your power and grounds in the entire car. There can be no serial communications without power to the computers that supply the communications.
Look at the fusible links under the battery and make sure the connections are tight.
Tom Piper
Good luck
Tom Piper
ok thanks for the responses, but to answer these questions, alright the fuel pump is fine and fuel system. ive already did the serial link to just the ecm and ccm without the asr and hvac system involved no change.
hers the kicker every no and then id say every 30 trys to start it the car will fire right up and run awesome, so thats why i havent changed the ignition module, i figure if it runs fine every once in awhile it cant be bad. as for the tach filter, i bypassed it by taking the two white wires and tying them together, still nothing, so put that back the way it was. now when the car does start and run fine, if i take it for a drive eventually the asr light and the security and sys will start flashing, that usaully means it wont start again if i shut it down, but its wierd cause if i wait 5 minutes or sometimes 8hrs the car might refire.
but lately the car hasnt been starting and staying running it has gotton worse, you guys are talking about these grounds where do i look for these? and remember the ecm is new and the ccm is new, they communicate if the car is running fine, but they lose contact with each other when the car wont start.
when i say the car wont start, it means the car will turn over and start, for a brief minute and die, so it starts but something tells it to shut down instantly. now i can keep it running if i catch it before it stalls but i have to stay playing on the gas pedal, it runs like ****, like its on 5 cylinders, popping and spitting, and once i let off it stalls,
i know for a fact it needs a o2 sensor it runs rich, but that cant be causing this electric problem, or the ignition module because it will run fine every once in awhile! maybe im wrong, but i think its the wiring between the ecm and ccm, or like it has a short or bad ground. where are these grounds im looking for??? again thanks for the insite everyone!!!
Look at the power terminal block that is behind and below the battery.
This is where several fusible links are connnected. These fusible links supply the power feed to many of the circuits in the car.
Make sure the connections are not corroded or loose.
There are ground connections on the back of the engine behind the oil filter where the engine mates to the transmission.
And, you are saying "new" ECM and CCM. Are you sure they aren't rebuilt/refurbished?
When there is an intermittent problem in these units and the technician can't get the problem to happen on the bench, guess what happens? They are considered OK and sold as rebuilt/refurbished. So, don't count them out completely.
Tom Piper
