Reverse Light Switch
Old Oct 19, 2004 | 08:42 PM
ddsovy's Avatar
ddsovy
Default Reverse Light Switch
Has anyone found an easy way to replace the reverse light switch on the ZF 6 speed? I've got a 94 without backup lights.
Thanks for the help.
Old Oct 19, 2004 | 09:49 PM
LD85's Avatar
LD85
On my 85, I dont think I could get to it with out taking my pipes off
Old Oct 19, 2004 | 10:44 PM
jfb's Avatar
jfb
I think I've read that the switch is the same as on my 4+3. I got mine off with a 7/8 socket that had to be turned on a lathe for a hex peak to OD dimension of .015 inch. Use a 4 jaw chuck and center the socket on the hex flats not the OD. Everything else I tried wouldn't budge the switch.
Old Oct 20, 2004 | 02:48 PM
87Z-ya's Avatar
87Z-ya
I just did mine. I broke the plastic off the bad switch so I could put a short 7/8 socket on it to get it out. Then I just used on open end wrench to put the new one in snug.
To Reverse Light Switch
