more speed!!
Old Jul 18, 2001 | 10:08 AM
jackyy's Avatar
jackyy
im thinking of putting in the fast chip and a cold air induction system....is that good for more power on my '91 L98 or should i change the throttle body also..pleeze help...im in south florida
p.s i dont want to get into engine work too much
thanx
Old Jul 18, 2001 | 10:15 AM
Nathan Plemons's Avatar
Nathan Plemons
Anything you can do to help the L98 breath is good, but don't expect huge gains. Just a little quicker throttle response.
Old Jul 18, 2001 | 10:32 AM
jackyy's Avatar
jackyy
thats all it will do?..what else can i do without getting inside that motor?i want to be able to take the mustang guys that act like king ****..
thanx
Old Jul 18, 2001 | 10:44 AM
Chris@SD's Avatar
Chris@SD
The chip and the cold air will help. Exhaust will also help a little and will give you a better sound. Pullies are always good for a few ponies also.
Heads and cam are the ultimate in power increase.
Old Jul 18, 2001 | 11:49 AM
Beach Bum's Avatar
Beach Bum
Optimize your current set-up first... most people can run several tenths quicker as they sit and don't know it.
Sticky tires and if you have an auto, a good torque converter will have the greatest effect short of going into the motor.
good luck
Beach Bum
Old Jul 18, 2001 | 12:53 PM
jackyy's Avatar
jackyy
thanx guys...torque converter how much would that run me?
thanx
Old Jul 18, 2001 | 02:34 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
check my the mods ive done on my site...
its taken off 1sec from stock.. not too bad.. no engine mods needed either!
you mean to say you cant take the mustang guys on now? hehehe...
Old Jul 18, 2001 | 02:39 PM
GlockLT4's Avatar
GlockLT4
Torque converters can run from $300 to thousands. A good one is the Vigilante. It runs $700 usually. A recommended stall speed for a street vette is 2600-3000. 3000+ is getting unstreetable (is that a word.. hehe)
Old Jul 22, 2001 | 12:49 PM
jackyy's Avatar
jackyy
ok i called ecklers and this is the setup the recommend....power chip stage 2...thermostat 160 deg. ...throttle body 52mm....cold air rammer....all this 830$ with shipping included..
they said it would give me about 40-50 hp...what do u guys think...in wanted to change the exhaust but cant spend extra money right now...im in south florida
thanx
Old Jul 22, 2001 | 04:03 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
thanx
[/color]
I'd opt for a Superram intake system for max real performance gains. The next one would be the Torque converter.
You should try the lower temp thermostat but I would skip the rest of those mods. 40-50 hp sounds a bit high. More like 10-15 and most of that will be from the thermostat change.
Old Jul 22, 2001 | 05:20 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Don't expect 40-50 HP from those mods, though they will be beneficial. Since you have a SD intake a chip is likely a good idea.
Check out the "easy" mods on my site, with results and cost. I've also removed that "frisbee" for a free 10 HP gain, added the March Underdrive crank pulley for .1 sec off my ET and am now trying to install 1.6:1 ProMagnum full roller rockers. Cutting back the spark plug ground electrodes is another free 10 HP.
I'm also sending you data from a CF build up on an L98. Sorry, if you want this info e-mail me and I'll respond with it.
To more speed!!
