Floor mount dimmer switch
Old Jul 19, 2001 | 03:00 AM
ASRoff's Avatar
ASRoff
Hey guys I just installed a old style ford head light dimmer switch on the floor of the 94' I can now turn my fans off and on by taping my foot on the floor!!! it works great!!! I can now leave my fans on untill after my burnout.
Old Jul 19, 2001 | 08:02 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Cool...how about a little description how you hooked it up and etc.?
Did you drill through the floor to secure it?Etc..
Old Jul 20, 2001 | 01:35 AM
ASRoff's Avatar
ASRoff
Well its pretty simple really, It had two leads black and red and two mounting holes. using the switch as a template I drilled the holes and used 5/16 bolts to secure it. I then spliced the wires into the wiring harness that I got from Corvette Central for the fan bypass. I figure you could use it for lots of things like nitrous arming, fans,an altnator cutout .....ect. Hell I may just install 35 or 40 of them and then I could hook the laptop up and type on the forum while I drive
Old Jul 20, 2001 | 01:48 AM
Aggravated4life
Originally Posted by ASRoff:
[B
Well its pretty simple really, It had two leads black and red and two mounting holes. using the switch as a template I drilled the holes and used 5/16 bolts to secure it. I then spliced the wires into the wiring harness that I got from Corvette Central for the fan bypass. I figure you could use it for lots of things like nitrous arming, fans,an altnator cutout .....ect. Hell I may just install 35 or 40 of them and then I could hook the laptop up and type on the forum while I drive [/B][/color]
Sounds great!!! Thats another reason I love the forum...once in a while, someone here(like you did) comes up with some really simple, but ingenious Ideas.
[img]http]//www.corvetteforum.cc/ubb/smile.gif[/img]
Old Jul 21, 2001 | 01:15 AM
ASRoff's Avatar
ASRoff
This is a great forum isent it? by the way Bill hows your car? is it back from the body shop?
Old Jul 21, 2001 | 09:01 AM
89 Bob L's Avatar
89 Bob L
Thats' a great idea.
To Floor mount dimmer switch
