Cooling system trifecta
Old Oct 22, 2004 | 05:28 PM
odysseysteve's Avatar
odysseysteve
Default Cooling system trifecta
My '95 coupe with about 60k on her just completed the trifecta - heater core failure, radiator failure and water pump failure - all at once! I had the heater core replaced professionally. I tried this job on another car years ago and also read about the difficulty of replacing the heater core on this forum. Well spent 500 bucks. Anyway, they noted that the water pump has a wet weep hole and now my radiator is actually dripping. I am going to replace the radiator myself (then the water pump soon) as funds are somewhat limited at this point in time. I was wondering if there is anything I should replace other than the radiator hoses while I have the radiator out. Also any tips or tricks that may help me out with this task would be appreciated.
Thanks!
Old Oct 22, 2004 | 08:39 PM
odysseysteve
ttt
Old Oct 22, 2004 | 08:51 PM
John Robinson's Avatar
John Robinson
Default Murphy's Law
It never fails when you shore up one weak spot it will show you the next. Especially if it's in the cooling and heating system
Old Oct 22, 2004 | 09:01 PM
ROYSREDROCKET's Avatar
ROYSREDROCKET
CHECK ALL OF YOUR GROUNDS,IT COULD BE A DIELECTRIC PROBLEM WITH EVERYTHING GOING IN A SHORT TIME FRAME.
Old Oct 22, 2004 | 09:49 PM
Trizney's Avatar
Trizney
Radiator is a very easy straight forward swap.
When you change the water pump, drain the coolant fromt the block as coolant will still be in the heads and drain all over the optispark (which you probally don't want to replace either) if you just drain the radiator (unless you maybe pull the lower radiator hose).
Old Oct 22, 2004 | 10:09 PM
Quiktrp94's Avatar
Quiktrp94
Check the Tech Tips section under Other on the Forums toolbar. Good tips by Lars on how to remove radiator. Robert
To Cooling system trifecta
