rear spring question.
Old Jul 20, 2001 | 10:39 AM
devilfish's Avatar
devilfish
What is the proper way to install and adjust a new spring to the rear. I have dropped my spring, and didn't remember how the "shims" where on the old one. How do I set-up the new one.
Have a nice summer..
Old Jul 20, 2001 | 11:24 AM
JonM's Avatar
JonM
This is from my 84 book, it should help you some.
http://www.corvetteforum.net/c4/jonm/spring.JPG
Old Jul 20, 2001 | 04:06 PM
VetteRacer282's Avatar
VetteRacer282
Here is how they are on mine, I know its not going to be the same spring most likely, but hopefully this will help you out some.
http://www.vetteracer.com/pics/Rear%...pacers%201.jpg
http://www.vetteracer.com/pics/Rear%...pacers%202.jpg
Good luck.
And as a note, I beleive each spring code had a different spacer setup. I dont know if the spacers do anything more then control the height of the car, so might be able to test a few spots untill ride height is good.
Old Jul 20, 2001 | 08:12 PM
vettenuts's Avatar
vettenuts
The spacer arrangement varies depending on coupe or convertible and the spring option of the car.
Old Jul 24, 2001 | 12:41 PM
devilfish's Avatar
devilfish
[/color]
So how can I tell witch setup i should use?
Old Jul 24, 2001 | 12:43 PM
devilfish's Avatar
devilfish
Originally Posted by JonM:
[B
[/B][/color]
Could you re-scan them? I cant read what it says. ]/
Regards
Old Jul 24, 2001 | 12:46 PM
vettenuts's Avatar
vettenuts
Post the year, model and options on the car. I will check my 90 manual for the correct shim arrangement.
Old Jul 24, 2001 | 06:02 PM
devilfish's Avatar
devilfish
[/color]
ok
with "soft ride" suspension.
Thanks for the help !
Old Jul 24, 2001 | 06:03 PM
devilfish's Avatar
devilfish
coupe
Old Jul 24, 2001 | 10:15 PM
vettenuts's Avatar
vettenuts
You have mail.
Old Aug 4, 2001 | 07:20 PM
devilfish's Avatar
devilfish
Default Re: (vettenuts)
Thanks for the mail
I got the FE1 setup on my car.
BUT how do I see If I have the "green" or "yellow" setup?
And Is the "spacers" the metal plates and the insulator the "paper like" shims?
So lets say i put 2 spacers (metal) abow and 1 under. Should I use the insulators to fil the "gap" abow the upper spacers? So there is no play?
Need some help..
Old Aug 5, 2001 | 10:43 AM
devilfish's Avatar
devilfish
Default Re: (devilfish)
vettenuts? any tips?
Old Aug 6, 2001 | 08:28 PM
h rocks's Avatar
h rocks
While you can move the shims above or below (to lower the rear) the spring, you must keep the total "length" of the shim pack the same as stock. So the easiest way to lower the rear without going radical, nor having to buy the long bolts is to simply relocate the shims to the underside of the spring. It will lower the rear ~ 9/16" to 3/4". After you reinstall your spring, be sure to get the car aligned, because the rear toe and camber will have changed.
Old Aug 7, 2001 | 08:38 AM
devilfish's Avatar
devilfish
Default Re: (h rocks)
well. vettenuts did send me a copy of a manul witch told me how do shims a C4. The only thing i dident understand whas that it was 2 option for my car ( FE1 ) one with "yellow spring code" and onw with "green spring code". How can I tell what I have?
Regards
Old Aug 7, 2001 | 11:52 AM
devilfish's Avatar
devilfish
tt
Old Aug 7, 2001 | 02:13 PM
JasonL's Avatar
JasonL
Somewhere on the spring, there should be a painted dot, yellow or green. It's about 1/2" in diameter. That should tell you how many shims to place where.
Old Aug 7, 2001 | 05:36 PM
devilfish's Avatar
devilfish
Default Re: (JasonL)
thank you my friend.
To rear spring question.
