LT1 Coolant Leaks...Why???
I've heard of intake manifold coolant leaks being common on LT1s. Is this true and why? If so how expensive is it to have it fixed? Is it because bolt patterns are too far apart? Bad gasket surfaces? Weak design, prone to warping? I'm looking into buying a LT1 and need to know more about it. Thanks for any help.
Bart
Bart
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
LT1 oil leaks are commojn on the intake because they used bad silicone when they built them. happens to the majority of them
Intake manifold oil leaks are common on LT1 due to sucky silicone sealant that fails over time. They never leak coolant though because coolant doesn't flow through the intake on LT1's. It's the waterpump that always starts leaking the coolant.
I've had a leak at the front of my manifold for as long as I've had the car (2 years). I really should fix it sometime!
[This message has been edited by Thud (edited 07-21-2001).]
Originally Posted by Lst-rd-c4
It will run about $350.00 at a dealer to have the intake gaskets replaced on a LT1. Had mine done 3 months ago.
[/color]
[/color]
