I run the RF 9's in the ZR1 due to the fact that with 11 to 1 compression it calls for 93 octane and we only have 91 octane available here. RF 5's would work fine for normal driving if 93 octane was available. One caution, if you go to a colder plug let that puppy warm up to operating temps before driving or you may experience plug fouling. Later, 84 CF 91 ZR1
I wouldnt really go more than a step or so colder... if your normally aspirated
I'm running a supercharger with about 9 pounds of boost with 91 octane it was nesessary as above mentioned to keep me out of spark knocks. I'm currently at 4 steps colder.
Primarily it slows the burn process to help reduce detonation. Under racing situations the car is going to be running hotter and you would be on the throttle most of the time which would be a perfect scenerio for spark knock or pre detonation. It will help you also get a bit more advance on the high end but as with anything it becomes a balancing act...
