Brake gurus please help!!
Old Oct 24, 2004 | 08:13 AM
Damien89's Avatar
Damien89
Default Guys need your help asap!!
When i press the brake pedal it seems that the booster is leaking air and the break pedal seems to softeen.
My mechanic told me that i need to change my booster and i found one at the corvette forum store that is made out of metal not plastic.
Has anyone ever used them, are they any good?
Old Oct 24, 2004 | 01:14 PM
midlifecrisis91's Avatar
midlifecrisis91
St. Jude Donor '03-'05-'06
I would think the metal one would be a good choice.
Old Oct 24, 2004 | 01:16 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If the pedal actually feels spongy, its a hydraulic problem, air in the system. You might just perceive it as being spongy, because of the air rushing noise from the brake booster.
When the booster DOES go, you'll hear the engine stumble, along with maybe the air rushing noise, and the pedal will get HARDER (less vacuum assist).
Sounds like yours may be in the early stages of dying, but I'd recommend doing a full brake fluid flush first. Metal will last longer, I think GM went with plastic to lighten things up a little, or maybe just to see if they could... I believe it's the first car made with a plastic booster.
Old Oct 24, 2004 | 03:08 PM
Damien89's Avatar
Damien89
Yes the engine does seem to stumble when i press the pedal and it feels as if the engine is loosing air from somewhere.
Old Oct 25, 2004 | 01:03 PM
Damien89's Avatar
Damien89
Anybody else maybe that has one?
Old Oct 25, 2004 | 01:57 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
The metal boosters were used only in 84 vettes and ZR-1's.
Old Oct 25, 2004 | 02:28 PM
Damien89's Avatar
Damien89
If they were used in ZR1s then that means they are better right?
To Brake gurus please help!!
