idle problem
Old Jul 22, 2001 | 12:27 AM
Laurie Landsittel's Avatar
Laurie Landsittel
Cruising
'93 LT1 has a bump/skip when in idle. Acceleration is great. Problem developed after I cleaned the throttle body & replaced gasket. I replaced the IAC valve & fuel filter. What can cause the idle skip?
Old Jul 22, 2001 | 04:00 AM
Ron78Z&66Vette's Avatar
Ron78Z&66Vette
If you haven't already, I'd double check just to make sure the bellows at the TB didn't fold under a bit on the bottom, allowing a small amount of unmetered air in.
Old Jul 22, 2001 | 11:13 AM
89AusVette's Avatar
89AusVette
Definitely need to adjust the new IAC, there is a great procedure under the "tech tips" C4 section.....simple procedure, all you need is a paper clip. I just rebuilt my throttle body yesterday and it purrs like new now...:O)
To idle problem
