85 IAC Valve
Old Oct 24, 2004 | 06:25 PM
selkirk24's Avatar
selkirk24
Default 85 IAC Valve
Could someone tell me how to check the IAC valve to see if it is working.
My car has a very erratic idle and I want to see if this valve is working properly.
Old Oct 24, 2004 | 06:43 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Here's a couple of threads that may help you.
http://forums.corvetteforum.com/show...ight=IAC+CHECK
Old Oct 24, 2004 | 06:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The IAC has a stepper motor which is pulsed by the ECM to move the pintel in & out of the IAC bore under the TB so you can't really test it.
Your best bet is to clean the TB and the IAC pintel & bore with some TB cleaner. Then reset base idle and TPS voltages; there are instructions on my site.
To 85 IAC Valve
