Master Brake Cylinder OR Booster???
1994 LT1 coupe. Stock breaks.
Problem: Breaks are all but gone.
My guess: I'm 99.9% sure the problem is my Master Brake Cylinder, or my Brake booster But can't get a satisfying answer on which.
Symptoms:
Top most of my peddle is a soft sponge. But half way (or more) turns into a rock.
Brakes work ok if pressing hard in the Hard part of the peddle movement.
A bit of a squishing sound (like liquid in a faulty hydraulic cylinder) heard from the master cylinder/booster area when i press the brakes lightish.. goes away when I push hard.
Facts:
New brake pads all around (this problem soon after)
New rotors rear, turned front
Zero brake fluid any where!
Reservoir 100% full and has always been there.
So I know I have to replace one of these to.. but would like to replace only the correct one... just don’t feel like throwing parts at the thing.
So advice, guesses, questions all welcomed.. thanks again guys!
Symptoms:
Facts:
Since you seem to have both symptoms(soft on top, hard at bottom) and seem to have just recently done or had brake work done, I would start with a good and thorough bleed of the system.
Also, generally, but not always, a bad vacuum booster will emit a "hiss" when pressure is applied to the pedal.
I am betting IMHO, a thorough brake bleed may solve the problem
seeya
Jack
Jack
Do you think air could get in my system from replaceing Pads and rotors??? Did it my self... I guess I don't see how. But not marking it off as not possible.
If you have vacuum test equipment, you probably could pull a vacuum test on booster to see if it is holding vacuum.
What concerns me is the "rock hard" pedal at the lower end. My experience with bad MC's is pedal never gets rock hard and goes all the way to the bottom unless you pump the heck out of it.
Sorry I can't be more definitive, but like you, I don't want to waste your money.
A full system bleed is cheap. Have someone step on the brakes a lot as you listen for vacuum leaks around the booster
Jack
Replace your booster.
My feeling is that its spongy.... Actually has been feeling weaker and weaker... Thats what led me to doing brake pads and suck (they where needed as well)
I very much notice it even with the radio on and I can't hear the noise.
P.S. anyone good good leads on where to buy these parts.... Or some used ones they have to sell?
First choice, the more you explain, is the MC!
Jack
So to other question... any suggestions/idea on good places to buy new/rebuilt/used?
Suggest strongly that you rule out "rebuilt"! Wear in the bore of the cylinder is the principal cause of failure. Rebuilding doesn't put metal back in the bore
Therefore, I would and have stuck with "new" I actually found mine on E bay a year or two ago. I hate to say this and maybe ashamed to admit, but I think a lot of new parts get stolen and
sold on e bay
I have bought a lot of new parts in GM/delco boxes, still in the plastic, at half price or less
Jack
