automatic trans "linkage" adjustment?
Old Oct 26, 2004 | 09:28 AM
rstackjd's Avatar
rstackjd
Default automatic trans "linkage" adjustment?
My '88 automatic runs through the gears just fine but I noticed yesterday that I cannot move the shift lever all the way to 1st. I also noticed that the indicator line is always a slight bit rearward of the selected position. I suspect this is just an adjustment somewhere but not sure where. I have a manual on order and won't start anything until I get it but I'd like your opinions as to where to start.
Old Oct 26, 2004 | 10:15 AM
CFI-EFI's Avatar
CFI-EFI
The linkage MAY need adjusting. It's unusual to go OUT of adjustment, but if it's been fiddled with... The adjustment is underneath the car, at the trans. The inability to select first gear is NOT unusual. Often it is because of folds in the boot that prevent the shift lever from moving as far rearward as necessary. You may have a combination of the two stacking up against you.
RACE ON!!!
Old Oct 26, 2004 | 10:21 AM
rstackjd's Avatar
rstackjd
Ah, ok thanks - in that case I'll llook at the boot first - sounds much easier to deal with. Glad to hear its not an unusual problem.
Old Oct 26, 2004 | 10:29 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
As far as the gear position indicator, that’s located under the plastic shifter plate and I don’t think it’s adjustable, but it may have slipped out of the grove that moves it.
You’ll have to disassemble and inspect.
Old Oct 26, 2004 | 10:33 AM
cv67's Avatar
cv67
St. Jude Donor '05
RACE ON!!!
Old Oct 26, 2004 | 01:52 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The most likely problem is the boot bunching up or not stretching enough; try to manually hold it in 1st gear to test this idea.
If the linkage needs a tweak, you will find a slotted link connected to a tranny lever on the left side of the A4. You can reach the nut by reaching under the car without jacking it.
Old Oct 28, 2004 | 09:55 AM
rstackjd's Avatar
rstackjd
WOW - you guys are GOOD! Sure enough - moved the boot around some and everything works fine.
Thanks again all
Old Oct 28, 2004 | 10:13 AM
comp's Avatar
comp
love the cheap fix's
To automatic trans "linkage" adjustment?
