VATS Bypass ???
Old Jul 24, 2001 | 04:44 PM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
A froiend of mine says they make a aftermarket ignition switch that eliminates the VATS. Anyone heard of this??? Im thinkin it would screw everything up
Old Jul 24, 2001 | 07:40 PM
MY 95's Avatar
MY 95
up
Old Jul 24, 2001 | 07:42 PM
Kale's Avatar
Kale
Check my sig:
Old Jul 24, 2001 | 07:44 PM
MY 95's Avatar
MY 95
any idea if it will affect the PKE operation???
Old Jul 24, 2001 | 07:57 PM
jfb's Avatar
jfb
Vats measures the pellet resistance of your ignition key and if it isn't within a few percent, then the start enable relay will not close and your starter will not run. VATS doesn't affect anything else. Bypassing VATS makes it easy for the dumb car thief to steal your car (most of them are dumb). I recommend you maintain your VATS function. I personally know some vette owners that had their steering column busted open , but the car stayed right where they parked it because the inept car thieves couldn't start it.
Old Jul 24, 2001 | 08:01 PM
MY 95's Avatar
MY 95
Originally Posted by jfb:
[B
Vats measures the pellet resistance of your ignition key and if it isn't within a few percent, then the start enable relay will not close and your starter will not run. VATS doesn't affect anything else. Bypassing VATS makes it easy for the dumb car thief to steal your car (most of them are dumb). I recommend you maintain your VATS function. I personally know some vette owners that had their steering column busted open , but the car stayed right where they parked it because the inept car thieves couldn't start it.[/B][/color]
thaks, considerin options, looks like I need a new ign switch [img]http]//www.corvetteforum.cc/ubb/smile.gif[/img]
Old Jul 24, 2001 | 10:36 PM
MY 95's Avatar
MY 95
ttt
Old Jul 25, 2001 | 08:41 AM
MY 95's Avatar
MY 95
ttt
To VATS Bypass ???
