85 L98 Compression Reading
Old Oct 26, 2004 | 10:52 PM
selkirk24's Avatar
selkirk24
Default 85 L98 Compression Reading
Hello
am wondering if someone could tell me what the compression should be on an 85 L98, mine is around 160 in most cylinders except for 2, which are around 175, ws wondering if maybe I have some carbon build up in these cylinders.
Old Oct 26, 2004 | 11:28 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Those two could be higher or the other six lower than when new.
Squirt a little motor oil into each cylinder and see if the others come up, if so it's ring wear; if not, it could be worn valve seats in the other cylinders.
Do the two higher cylinders pump up faster than the others?
Old Oct 27, 2004 | 12:14 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Was the engine warm? And were the high ones the first you measured or....? How many cranks it takes to reach the pressure is very important, take note of the approx pressure after each rotation, it should make it there on the 3rd or 4th turn.
Those numbers sound good btw. I got 180-190, but that was on a hot engine, and everyone elses numbers are close to yours.
Old Oct 27, 2004 | 11:24 AM
85blkrose's Avatar
85blkrose
Default compression
getting ready to do mine. should it be warm? if my number are good i am leavin the bottom end alone, i already know my valve seals are shot
got new heads to take care of that
Old Oct 27, 2004 | 02:25 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by selkirk24
Hello
Your numbers are in the ball park. It's best if they don't vary more than 10%. Your's are right inside of that. The compression ratio, and more so the cam timing, determine what it SHOULD be. Your '85 and my '84 have identical long blocks. Mine tests at 165# - 175#. I have 160,000 miles on mine and it burns a ton of oil, but it'll STILL run a 13 second 1/4 mile.
RACE ON!!!
To 85 L98 Compression Reading
