ESC Module upgrade
Old Oct 26, 2004 | 11:14 PM
johnkw's Avatar
johnkw
2nd Gear
Default ESC Module upgrade
I just purchased an upgrade for my ESC Module. According to the C4 manual I have it show the module location as being on the right side of the blower. This is not the case on my 1996 LT 1 its not there. Is there another location for this upgrade?
Old Oct 26, 2004 | 11:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The ESC module was used only on '85-'89 L98s.
Old Oct 27, 2004 | 12:06 AM
Corvette0096's Avatar
Corvette0096
Old Oct 27, 2004 | 12:21 AM
mikey whipreck's Avatar
mikey whipreck
in the LT1/4's the ECM listening to the knock sensor directly.... only in early l98's did the ECM go through the ESC to listen to the knock sensor
Old Oct 27, 2004 | 02:06 AM
BAM92's Avatar
BAM92
On the 93-96 LT1's the ESC upgrade I believe goes under ECM. https://shop.madirect.com/cart?carti...0Lb83gCk1wMg19 If this is what you are refering to.
Old Oct 28, 2004 | 07:19 PM
johnkw's Avatar
johnkw
2nd Gear
Default Thanks
I will check it out.
To ESC Module upgrade
