Z51
Old Jul 25, 2001 | 12:30 AM
ezeneli's Avatar
ezeneli
I have a 1987 vette automatic how can I tell if it has the Z51 package?
Old Jul 25, 2001 | 12:46 AM
BiZ's Avatar
BiZ
Open the drivers side rear storage compartment. There is a list of RPO codes there. If Z51 is one of them, you have the Z51 option.
Old Jul 25, 2001 | 12:51 AM
Nitro Junkie's Avatar
Nitro Junkie
Steering wheel is 2 turns lock to lock for Z51. 2-1/4 - 2-1/2 turns for standard.
Old Jul 25, 2001 | 12:57 AM
scorp508's Avatar
scorp508
Well the easiest way is this. You have an automatic. Z51 was restricted to manual coupes in 1987. You "might" have Z52.
Old Jul 25, 2001 | 01:05 AM
ezeneli's Avatar
ezeneli
what is the Z52?
Originally Posted by scorp508:
[B
Well the easiest way is this. You have an automatic. Z51 was restricted to manual coupes in 1987. You "might" have Z52. [img]http]//www.corvetteforum.cc/ubb/smile.gif[/img][/B][/color]
Old Jul 25, 2001 | 11:52 AM
Rick Williams's Avatar
Rick Williams
ezeneli, I have an 87 Z-52 automatic. The only way to be sure as to what you have
[ Z-51, Z-52 or basic suspension coupe] is with your build sheet or window sticker which shows the RPO code Z-52.
My steering wheel turns exactly 2 turns as the Z-51.It also has several of the other Z-51 options as well.
Scorp is right as to the 87s and the manual transmission.
Order the build sheet and window sticker for your Vette from the Corvette Museum. Good luck
Old Jul 25, 2001 | 11:56 AM
scorp508's Avatar
scorp508
Look on the bottom of your center console lid. As long as this piece has never been replaced, there should be a sticker with all of your RPO codes on it. See if Z52 is on there.
To Z51
