Yep, that's the one. If you are replacing it, be sure to use that supplied anti- heat grease that usually comes with a new module, to prevent frying your new one from heat.
thanks guys i got it replaced but the car still not starting . im getting fuel and spark all the wiring is good but for some reason she dont want to start ????
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Are you sure that is anti-heat grease? Would it be more likely to be a heat transfer grease to help dissipate heat from the module to the surrounding base metal?
