Fuel Pressure Gauge Question
Old Oct 27, 2004 | 06:49 PM
gpagaduan's Avatar
gpagaduan
Default Fuel Pressure Gauge Question
Over two years ago I bought a new fuel pressure gauge to get readings for my fuel injector swap project. Got the before and after readings I needed, job done...put the gauge away. Fast forward to the present...I break out the gauge to trouble shoot an intermittent drop in rpms problem and some near stall incidents. Anyways, the fuel pressure reading is a big fat zero?? The car always starts up on the first crank, the car drives strong, and at WOT the car really goes. Do you think that on the third time use of my gauge that the darn thing is already bad? Or is there some unusual circumstance that my gauge is ok and that my fuel pressure is really nil? Sounds ridiculous but I had to ask. I guess I can always run out there and buy another gauge, but that's another $40 that can be put to better use. BTW, it's one of the ACTRON gauges from Autozone with the pressure relieve button and hose.
Old Oct 27, 2004 | 06:56 PM
1MoorTym's Avatar
1MoorTym
Pressure is pressure, why don't take the gauge to an air pump and see what see reads - you obviously have fuel pressure
Old Oct 27, 2004 | 07:13 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I have one of those gauges and used it on the IROC for about 5yrs.
Do you have any pressure at the Schraeder when you install the gauge?
Old Oct 27, 2004 | 07:53 PM
gpagaduan's Avatar
gpagaduan
Yes, it's the gauge that you use at the schraeder valve.
Old Oct 27, 2004 | 07:55 PM
gpagaduan's Avatar
gpagaduan
Yes, it the gauge installed at the schraeder valve.
Old Oct 27, 2004 | 07:59 PM
USAsOnlyWay's Avatar
USAsOnlyWay
....take it back to autozone and ask em to test it for you?
Old Oct 27, 2004 | 08:29 PM
JackDidley's Avatar
JackDidley
I had 2 of those go bad within a year. Now I have a SnapOn.
Old Oct 27, 2004 | 09:27 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check the end of your gauge hose and see if the pin in the middle will fully depress the the valve on you fuel rail. My hose has an adjustment to set how far that pin will extend when the hose is fully threaded on.
Depress the shraeder valve with something. If there is pressure above 0 lbs, you'll quickly find out
Old Oct 28, 2004 | 12:33 AM
gpagaduan's Avatar
gpagaduan
We have a winner!!! It looks like the pin in the connector for the hose broke off. Duh, I should have noticed that!!! And yes, I did take a small flat head to the schraeder valve and leaked out just a wee bit of fuel. Does anybody know if the hose with the connector is replaceable?
Old Oct 28, 2004 | 03:26 AM
AGENT 86's Avatar
AGENT 86
http://www.grainger.com/Grainger/pro...711128&ccitem=
Old Oct 28, 2004 | 09:09 AM
comp's Avatar
comp
To Fuel Pressure Gauge Question
