Super Ram Questions....
Old Jul 26, 2001 | 06:23 PM
Nomar116's Avatar
Nomar116
Ok, so Im getting close to pulling the trigger and getting a super ram. Im currently building a 383 stroker with a 5.7" rod, hyper pistons (cant find forged to keep compression down on stock heads) three angle and pocket ported heads, hooker long tubes, LT4 Hot cam with a 1.5 or 1.6 roller rocker, air pump eliminator, all on an automatic with a shift kit and 2400 stall converter. What times can I expect with and without the Super Ram intake system. Also, What all is necessary to do the install. Can I use the stock fuel rail? All Im looking at purchasing is the Intake plenum runners and manifold... Will that do the trick. Its from a fellow member as well so I think its been installed and modified for that install. Just looking for experience here.
Paul
Old Jul 27, 2001 | 10:36 AM
xcheck's Avatar
xcheck
Cruising
Your short-comings will be the cylinder heads. I'd have them professionally (CNC if possible) ported to take advantage of the better flowing intake. If you go with the Super Ram and a bigger cam without opening those heads up you won't be as happy as you can.
Old Jul 27, 2001 | 02:48 PM
Nomar116's Avatar
Nomar116
Im already having them pocket ported and a three angle valve job. The machine shop may have opened them up even more but thats all I know of. The 58mm will have to wait I think, Ill stick with stock assemble the motor, and then replace that throttle body in a few weeks.
Paul
Old Jul 27, 2001 | 03:11 PM
-=Jeff=-'s Avatar
-=Jeff=-
Even with the stock heads pocket ported you will still will not see the full effect of the motor... I know this first hand..
Last year I installed an new 355 in my vette.. approx 10:1 compression with a ZZ9 cam, Miniram, 52mm TB, Full length headers, PFP Cat and Flowmaster cat back..
My best 1/4 mile time was 13.82 at 99mph
This past winter I changed 2 things.. I swapped the pocket ported heads for CNC L98 heads, and installed two Random 2-1/2" cats with a LT1 Flowmaster cat back..
My new best is 12.82 @ 110 basically.. only change was heads and exhaust. I honestly think you should consider CNC'ing your heads. now is the time while it is apart.. you won't regret it...
Old Jul 27, 2001 | 07:04 PM
84willnotfire's Avatar
84willnotfire
What does cnc mean?
Old Jul 27, 2001 | 08:56 PM
Diletante1's Avatar
Diletante1
7th Gear
This is a very similar sounding set-up to the 383 I had built (and am trying to sell in the other forum). I can tell you from experience that you really don't need the 58mm TB with the set-up you've described. You'd probably benefit from a 52mm but a 58mm would be a slight bit of overkill (possibly slightly more HP up top but you'd be a bit more sluggish in the RPM range you'll be in most the time). I must say I've absolutely loved my SuperRam.
Old Jul 27, 2001 | 09:47 PM
Nomar116's Avatar
Nomar116
Thats exactly what I want to hear diletante. Im going to go ahead and buy it off the forum member. I hope everything works out, Ill probably need alot of help on the install. Ive heard of much better numbers than 13.8 out of the stock heads, much better. I could of gotten that out of sticky tires and my stock setup. We'll see how everything comes together, I think the custom chip I have printed will really pull it all together also.
Paul
Old Jul 28, 2001 | 02:00 PM
corvette1990's Avatar
corvette1990
Your setup sounds awesome. The stock fuel rail will work, but put in a replacement set of Orings (cheap). Larger injectors (#24's) would also be nice at this time. (Thats what I did). I went with the 52mm throttle body too. I have the SR install instructions in MS word if you need them, along with hints from forum members. I also went with new sensors. You will be asking soon where to mount that Map sensor plate. Try to replace as many rubber vacumn hoses as possible. Good Luck. Chris
To Super Ram Questions....
