moving car after tranny removal
I am about to remove my tranny, and work on my car for the next year or so and plan to move in 4 months, now am I able to move my car onto a trailer without the tranny and drive shaft in place or would this lead to some problems? Or is it best to wait 'till after I move? Any ideas would help, thanks.
Seth
Seth
Cruise-In II Veteran
i knew there wasnt something wrong with my car when it rolled off the jackstands. hell i figured if i left it in park before i took the transmission out, it would stay in park
You're better off removing the drive shaft from the car at this point. Change the u joints while the trans is out and put the clean shaft in the back of the car. This way for sure you won't be dragging it around. It WILL spin so tying it up would be a bigger hassle.
I hate to say it but you guys are wrong. The tranny is the rear support for the engine. When you remove the tranny you have to support the rear of the engine w/ a jack or something or it will lean on the fire wall & do damage to the dist. evan w/ the cap removed. Take my word on this I just instaled an ac delco reman trans which was defective so I had to do it twice.
Reeltime is right you MUST support the rear of the engine, it can damage the motor mounts too if you don't. Also make index marks on the splines and driveshaft to avoid any vibration problems on reinstallation.
[/color]
[/color]
