? On Code 54
Old Oct 29, 2004 | 01:52 AM
C4Ownr24's Avatar
C4Ownr24
Default ? On Code 54
Alright, last question (for now....) So if the vehicle sets a code 54 (high/low fuel pump circuit voltage) is that basically telling me the relay is shot? where is that voltage measurement taken - at the pump? What sorts of things do I need to be looking at. Keep in mind my '85 vette still runs and drives, but has seemed to lose just a bit of ***** the past couple of days, and idles a bit rough. Does it sound like a fuel pump gone bad?
I also have the following codes, for reference purposes:
Code 52 - calpack missing or faulty
Code 53 - system voltage too high.
I am sure my alternator isn't overcharging. The vehicle has a hypertech thermomaster chip in it. Any suggestions?
Old Oct 29, 2004 | 02:21 AM
bogus's Avatar
bogus
I have seen those codes before, and they have befuddled the hell out of me, too.
They are somehow connected... and I think they are the result of a bad calpack or memcal.
The 85 has such a crude computer... you may want to investigate updating it to the ECU from an 87.
Old Oct 29, 2004 | 09:03 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2054.pdf
Old Oct 29, 2004 | 02:41 PM
CFI-EFI's Avatar
CFI-EFI
No! It does NOT sound like a fuel pump gone bad. If the pump were bad or weak, you would have worse drivability problems. The engine will run just fine with the oil pressure switch powering the fuel pump. Chances are the code 54 was triggered by a "bad" reading at the fuel pump relay. That MAY be the relay or it could be the wiring or other things. DON'T replace the relay based on the code, only. Trouble shoot it. *I* don't know how your other codes interact with the code 54. My guess is that they don't. THEY could be the cause of the drivability problems.
RACE ON!!!
To ? On Code 54
