I keep the blue/transparent top on my car and have recently noticed something that looks either like a crack or craze near the front right (passenger side) corner of the top. I say it may be a craze since it seems to be below the surface when looking at the top from above. Unfortunately, this occurs in the area covered by the frame of the top (i.e., I cannot look at the acrylic in this area from below or by removing the top).
Questions--anyone else notice this? Does GM cover replacement (I know it's beyond the 3 year warranty but the top is really a structural component of the car)? Is it necessary to replace the entire top (frame and all) or can the acrylic piece just be replaced (I would think this should be cheaper)?
You'll find that a certain amount of "crazing" or the "spider web" look is normal for the acrylic tops. It's caused by the small amount of flexing that takes place when you drive.
The choices are really to either live with it or replace the top.
On the other hand it is actually cracked through the acrylic then you should replace the top. I don't think there is a way to repair an actual crack in the material.
You should see mine. The entire thing is spider webbed and cracked. It looks really bad when you sit in the car and look up. It shouldn't cause you problems like leaking, etc. It's mainly cosmetic.
My glass top is the same way, peeling and a few cracks here and there, It looks terrorible, but thats why its been sitting here next to my desk for a while, My painted top is better in the heat anyways!!
Let us know if you find some way to fix it for low$$$, I'd be very interested.
My car came with this static cling tint material on the bottom of the acrylic top. It works pretty well. I only took it off once when I first got the car (about a year ago). It was a pain to get back on because it has so much static. My top is a bit cracked up, but you can't see it too bad through this stuff. You could probably use regular old window tint, although this stuff will probably hide it better and fits. They sell it a Mid-America I think.
My glass top is the same way, peeling and a few cracks here and there, It looks terrorible ...snip... Let us know if you find some way to fix it for low$$$, I'd be very interested.
Thanks for the replies. I am not overly concerned if this turns out to be a "craze" rather than a crack. As I mentioned, I cannot inspect it from the underside as the structure of the surrounding top frame covers the acrylic where the "crack" occurs. I can say that it seems to have gotten slightly longer over the last several days--now about 1.5" long and just one almost-straight line.
I think we should expect more for a car that stickers at $40,000+. After all, the top in the C4s is definitely part of the structure of the car.
