What should a rear brake job cost ?
I went to my local Delco tire shop yesterday to have a nail removed from my left rear tire and get a price on new tires. While the wheel was off the car, the tech alerted me that the rear brakes were almost gone and that I needed pads very soon (38,000 miles on the car and I think that I have only replaced the fronts).
Anyway, one of the guys called his parts suppliers and quoted me about $200 just for the pads (oem)! and $300 for the total install including the pads, turn rotors, etc.
Based on my browsing through Ecklers and MAD catalogs, the $200 seems way excessive. Anyone have an idea what a fair price is for rear brakes?
As an aside, the supposedly "great" price they quoted for tires also left alot to be desired--BF Goodrich Gforce TA fronts at about $250 each--seems I should be able to do better.
I just did my rears not too long ago.. It takes about 10-15 min a side. Figure 1/2 hr a side shop cost, 70/hr so $70 for labor.
Paid $55 for my pads.. Figure you're going to pay about $80 for pads. Total cost= $150ish.
That said, if you have BASIC tools you can do them in the driveway without too much hassel.
[/color]
[/color]
Thanks for the info. Frankly, I am beyond the point where I enjoy working on my car (those days are long past). So I don't begrudge the $70 labor but I did suspect that the $200 for pads sounded outrageous.
Cruise-In II Veteran
the back brakes are extremely easy to work on. you might wanna consider doing it yourself. you have to take off two bolts to remove the caliper, press the piston back in the caliper with a c-clamp, put the new pads on, and then just bolt it back up. pads in no way shape or form should cost 200 dollars.
Just did my rear pads last week and the hardest part of doing them was getting the wheel off and the run to checker auto to have the disc turned, MY cost for ac delco pads was $16 dollars and was $8 to have each disc turned and belive they needed it, as far as your tires go to to costco, I bought 27/40/17 zr, kdsw in January,bf goodrich g force for $139 apice, its your money, might as well spend it wisely.
traxx1
traxx1
I just got done doing front and rear brakes.
I have the 13" grand sport brakes in front so the pads were more. AC Delco front pads cost $150, rear pads cost $50. Rotors cost $15 each to be turned.
I took me longer because I took the time to check wheel bearings, bushings, etc.. and clean up the suspension and make it look purdy
Under $300 for the whole thing doing it myself and knowing it was done right.
I got a quote from a dealer back in WA when I lived there and they stated $149.99 +tax. So you are getting ripped off. Go someplace else for any work now or in the future.
I did my rear brakes myself and spent less then $100 for the whole deal.
Just did my rear pads last weekend. I found that there was quite a price difference from dealer to dealer. One Chevy dealer quoted me $70. Another $41. Talk about mark-up. Super easy job. Do it yourself.
Thanks for all the responses. I stopped by my local independent guy who also does restoration (Javier's in Van Nuys) and he said the pads are about $70 max. He would do the entire job including turning rotors and bleeding for about $150--sound fair to me.
Traxx1--thanks for mentioning Costco. It didn't occur to me that they would carry high performance/wide/low profile tires. There are 2 Costco's near me and I will check that out.
Dealer hear runs a special on them for around $129. I went with new rotors (from TLD) and ceramic pads. I still didn't pay that much. All told I think it was about $350 total out the door tax and BRAND NEW rotors.
