Gauge install question
Old Oct 30, 2004 | 10:49 AM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Default Gauge install question
For those of you with your boost and fuel pressure gauges on your a-pillar, where exactly did you run the wiring and vacuum tubing through to the engine bay? Did you have to drill a hole, or is there one already there? Also, on the autometer electric fuel pressure gauge, the directions say to put a fuse in the wire that goes to +12v ignition. Is this necessary, and where did you wire it to, a switched fuse in the fusebox, or an actual wire near the ignition?
Old Oct 30, 2004 | 08:37 PM
Bruce's Avatar
Bruce
Remove the battery there already a hole in there, just run the wiring thru. As for the 12V, you can get power from the fuse box or the ignition switch.
Bruce
Old Oct 31, 2004 | 12:02 AM
Mo_Bandy's Avatar
Mo_Bandy
I'm running a regular pressure fuel gauge, I'm using a transducer thats located above the battery. I suggest using a fuse in the remote event that something happens to the guage, it will blow the fuse rather than having 20 amps frying the wires...
Mo
To Gauge install question
