one more EGR question
Old Oct 30, 2004 | 05:48 PM
SuperDave90C4's Avatar
SuperDave90C4
Default one more EGR question
on the label that shows the vacuum lines that run the emission system it show that for the egr valve it comes off the TB and splits... one goes to the egr valve solenoid and the other goes to the carbon canister... the PO replaced the engine and the plastic vacuum supply line to the solenoid was broken when i got it... the problem is when i got it the vacuum connection that comes from the bottom of the TB was connected to one small vacuum line going to the carbon canister... I spliced into this line with a vacuum splitter and the EGR valve code goes away but i know have a very noticible miss at constant speed... as in a previous post it could be a possible injector... but when i spliced this line i got a lot worse... did i splice into the wrong line?
Old Oct 31, 2004 | 09:50 PM
SuperDave90C4
please
Old Oct 31, 2004 | 11:03 PM
cv67's Avatar
cv67
St. Jude Donor '05
What year is your car?
Old Oct 31, 2004 | 11:11 PM
SuperDave90C4
1990 Auto
Old Oct 31, 2004 | 11:45 PM
Trog's Avatar
Trog
Sounds right to me. I just capped those ports to the EGR a few weeks back & initially tried to elim. that splice but didn't want to break anything in case of future return of EGR system.
To one more EGR question
