How to replace cap and rotor?
Old Oct 30, 2004 | 08:16 PM
dailo's Avatar
dailo
Default How to replace cap and rotor?
Hi.
I have a 91. Is it easy to replace the cap and rotor?
If so, how easy and whats the procedure and how long should it take, or should I not even bother, and let the shop do it.
Old Oct 30, 2004 | 08:23 PM
bogus's Avatar
bogus
yes.
20 minutes, max.
the distributor is near the firewall. remove the cover, remove the cap, remove the rotor, reinstall.
mark the wires in relationship and transfer them one at a time to the new cap.
Old Oct 30, 2004 | 08:24 PM
bmalec's Avatar
bmalec
While I've haven't changed the cap and rotor yet on my '89 L98, it doesn't look too bad at all--might be a bit tough getting to some of the screws that hold down the cap, but doesn't look impossible.
I'd guess it would take about an hour to remove and replace, assuming you've never done this before and you're taking your time.
Ben
Old Oct 30, 2004 | 08:25 PM
bmalec's Avatar
bmalec
Blah, Bogus types faster than me!!!
Ben
Old Oct 30, 2004 | 08:29 PM
dailo's Avatar
dailo
Wow thanks for the quick response.
Is there a grease or something you need to use, or is it as simple as unscrew and rescrew?
Thanks again
Old Oct 30, 2004 | 11:14 PM
bogus's Avatar
bogus
bmalec - I type fast!
dailo - you will want some Di-electric grease for the wires. Makes them more moisture resistant. Which in Hong Kong is a good thing. Also makes them easier to remove.
Old Oct 30, 2004 | 11:28 PM
cv67's Avatar
cv67
St. Jude Donor '05
Ben
Easiest way I found is a 1/4 inch drive ratchet, and a flexible 1/4 " drive steel extension I found at OSH in the tool section. Also works great for the lower runner bolts using a 1/4 to 3/8 adapter right before the Torx bit!
To How to replace cap and rotor?
