Anyone remove the ASR from thier car?
[This message has been edited by ScaryFast (edited 07-30-2001).]
You cannot "remove" the ASR without taking the ABS with it...
also, don't even think of driving one of these things in the rain without ASR... beleive me... the first lane change, rear first, that you do without wanting to, will make you wish you still had ASR...
If you really wanted to get rid of it, remove/modify the servo that plays with the throttle...
Under the hood, on the left engine bank is a box labeled "ASR". Under it is a plug. Disconnect it. You "ASR" is now dead until you plug it back in (and this will not effect your braking system in any way). The unplugging of ASR, however, will cause a warning light to display on your dash. Put a small piece of black tape over just that one light and then buy an aftermarket smoked glass "Information Cover" and snap it in place on your console. This will let all the other lights shine through but block only your "bad" lights. The tape is virtually invisible behind the smoked "Information Cover" glass.
http://www.ecklers.com/dept.asp?dept_id=1600
ASR is now gone until you sell the car (or it snows). Can't think of any other time you might need it. Its a BLAST!
Total cost: about $35
Total time: about 3 minutes
Besides, I have much bigger issues with inclement weather than traction control, such as zero ground clearance and tires with no tread. It's a track car, mostly, although it's still street legal.
Even that one time, I still disabled ASR, as I'm a much better driver than the computer is. I do need ABS, however, so if they're hopelessly linked than I guess I'm in a bit of trouble. Where is the servo that jerks the pedal? I'll pull that off in a heartbeat!
