That is good general advice but in this case, if you have a '85-'89 L98 that mod will give crisper throttle response and improve power at part throttle acceleration.
Is it worth the time or effort to adjust the TPS from .54V to .60 or .65V on the L98
I don't think so, considering the spec is .54 +/- .08 which is .46 to .62. It may, repeat may, give you better off idle repsonse but I don't really think you'll notice, nor has that ever been proven. Make sure you've within spec and more importantly that you've got max approx. 4.5 volts at WOT.
I've got an 85 that had an off idle stumble that was driving me nuts. I set the TPS at .65 and it's a different car with no side effects whatsoever. Go for it.
when i bumped my idle to .65 i noticed when i come to a stop my idle goes up to like 1100rpm's then drops back down????? this happened as soon as i bumped tps
