Emergency brake will not work
Old Nov 1, 2004 | 12:20 PM
Teenangel's Avatar
Teenangel
Default Emergency brake will not work
Help I have a 96 LT1. I replaced the rear pads. I used a tool to Push in the Caliper piston. Since then my emergency brake will not work.
Any ideas out there?
Old Nov 1, 2004 | 01:26 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On my '88 it isn't necessary to adjust the parking brake unless the calipers have been serviced.
What is the parking brake failure mode, i.e. does it not hold the vehicle, does it not move the pads?
Have you applied/released the parking brake 3 times, to set the auto adjuster?
Old Nov 1, 2004 | 01:45 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
If you've already reset the piston position then you should just have to set and release the brake several (read: can take 20-30 times) to re-set the auto adjuster just like 65Z01 said.
To Emergency brake will not work
