Cam Replacement--What is involved?
Old Nov 4, 2004 | 09:01 AM
dslater35's Avatar
dslater35
Default Cam Replacement--What is involved?
Greetings from the technically challenged!!! I've been around cars and motorcycles for well over 30 years and have twisted a few wrenches. What is involved from a high level in a C4 cam swap. I don't need the mechanical side of the equation as much as I need to know about the removal of body components... For example in a couple of previous vehicles I could remove the radiator along with the grille and few other components for easy access. Compared to that scenario what am I looking at with a C4 (it will probably be an L98).
Thanks for your help!!!
Old Nov 4, 2004 | 09:14 AM
shotchkiss's Avatar
shotchkiss
Radiator needs to come out, A/C condensor can be moved out of the way. No body panels need to come off. One motor mount bolt may need to be removed to slightly lift the motor for clearance when removing and inserted cam. Of course, the intake manifold, water pump, and most stuff bolted to the front of the engine needs to come off, along with dropping the oil pan some.
