Interior brake light coming on, going off
Old Nov 5, 2004 | 08:40 PM
redsand's Avatar
redsand
Default Interior brake light coming on, going off
I have an 86 c4 and for some reason my interior brake light is coming on. I will start driving, no light - first time I press the brakes, light comes on. Usually some time later during the drive, the light goes off. Very strange - only variable since I've gotten the car is colder weather. Perhaps brake fluid? Any ideas?
Old Nov 7, 2004 | 12:49 AM
Mo_Bandy's Avatar
Mo_Bandy
I'd be checking your master cylinder... it may be sensing that you don't have the correct pressure in the brake system. if you see the fluid is low it could also mean you are close to needing brakes as well...
just a thought ...
mo
Old Nov 7, 2004 | 10:26 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
just a thought ...
mo
Check your fluid level and check out the switch for a problem.
Old Nov 7, 2004 | 10:37 AM
AGENT 86's Avatar
AGENT 86
I just uploaded this for you http://members.shaw.ca/dankai/Brake%...g%20System.pdf
Old Nov 7, 2004 | 05:23 PM
redsand's Avatar
redsand
Thanks a lot mate! Will do...
Old Nov 8, 2004 | 09:18 AM
Unriced's Avatar
Unriced
My e-brake wasnt entirely disengaged once and it caused
an intermittent flashing of the brake light as you describe..
Had to push the button in and make sure lever was in the
down position all the way..
My 2 cents..
Old Nov 8, 2004 | 02:38 PM
Square's Avatar
Square
My E-brake handle was also causing my Brake light to flash and come on intermittantly. I took the handle cover off and the piece of metal that breaks contact had bent over the years. I bent it back with a pair of pliers and it has worked ever since.
Old Nov 8, 2004 | 05:48 PM
redsand's Avatar
redsand
Yes, I have an automatic, and the parking break is on the left of the driver's side seat of course. The strange thing is, I push the button, try to pull it up - it doesn't budge. Something is obviously wrong with it, and, dumb me, I didn't check the e-brake when I bought the car because the light wasn't on, didn't come on, and actually hasn't come on for a month. When the light did come on - the one in the middle console with the (P) and (!) symbols - I tried pushing the e-brake or parking brake down even though I couldn't budge it up, and nothing happened. It doesn't really go down that much either. I didn't wanna push the button and yank up too much, and brake it ya know?
Ah well, I guess perhaps the parts manual will give me some insight on how to take that ebrake apart and see why its not moving. I have no clue. Hope to get the parts manual soon.
To Interior brake light coming on, going off
