50MSpts injectors
Old Nov 6, 2004 | 06:18 PM
subman's Avatar
subman
Default 50MSpts injectors
Just finished a friends 88 injector swap after having leaks on all the new injectors. So I figured it might help someone else, since it took a while to figure out what and how, to make the leaks stop.
First off, I have the same injectors in my 91 (the pink top ones) and they installed without any problems. This 88 has apparently has some minor differences in the fuel rails and injector ports that won't allow the seals to seat both top and bottom. The 50 M.S. injectors are about 3/16" shorter than the stock injectors. After leaking on every the first installation 2 weeks ago (it's was also 6:00 PM on a Sat.) we re-installed the old injectors with new seals. We started again this AM. Finished injector swap, installed new plug wires, fuel filter, O2 sensor, drained and re-filled differential in less than 6 hours, even with some problems.
Here's the fix(es):
1- get larger seals. The new seals are about 1/32" larger OD and sealed all but 2 injectors.
2- file the towers on the manifold. We took about .020+ off the four towers with a file.
Since the fuel rail has some play, it doesn't seem to need to be "exact". Make sure that all the shavings are vacuumed up.
We re-installed the rails and tested. No leaks!
So, If you opt to get the 50MS injectors (for the bucks and the service from Bruce, the are terrific), make sure you get the larger seals, check for leaks before you re-install the runners and plenium, and if necessary, file the rail towers.
BTW, Bruce was pretty helpful with information over the phone when we first started this project and had problems. He really is a stand up guy.
Old Nov 6, 2004 | 07:30 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I had to do nothing to my 86 when I installed the pink tops. I used the O rings that came with them and used my factory clips.
Old Nov 7, 2004 | 08:01 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
ME2---put a set in my `87. No problems at all. Runs fine
Old Nov 14, 2004 | 10:06 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default O-rings
where can i get o-rings that are slightly bigger than the one I have on my injectors. do I need to reuse the small metal clip off my old injectors and put them on my new ones.
To 50MSpts injectors
