new coolant.
Old Nov 7, 2004 | 10:29 PM
larryfs's Avatar
larryfs
Default new coolant.
anybody see this new antifreeze. I went to buy regular green freeze, and all I can find was this new prestone
"CAN MIX WITH ALL COLORS"
they had the dexcool too, but no more regular green freeze.
so I brought a gallon, and low and behold it is green, but it's compatable with dexcool.
new to me
Larry
Old Nov 7, 2004 | 10:32 PM
Draven's Avatar
Draven
St. Jude Donor '14
There was a thread not too long ago about this -
I've been using it now for a month. My car runs cooler.
-Joe
Old Nov 7, 2004 | 11:23 PM
mikey whipreck's Avatar
mikey whipreck
as long as your not mixing dexcool, you should be okay
Old Nov 8, 2004 | 03:11 AM
LT4fun's Avatar
LT4fun
I bought some Walmart Super Tech extended life antifreeze for my wife's Honda Accord as the thermostat was stuck open. After doing some research, it's made by Prestone.
(check the msds number to be sure as this can change)
http://msds.walmartstores.com/msds/t...9/00028900.tif
Now I only plan on using the Texaco Dexcool in the 'Vette, but knowing the SuperTech Extended life antifreeze is made by Prestone might be useful on daily drivers.(if you feel lucky)
Old Nov 8, 2004 | 07:04 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You might wanna' rethink that. Honda is pretty particularly about O.E.M. coolant, power steering fluid and ATF. In fact, you can void your new Honda warranty if you DO NOT use them.
Honda has sent the information attached below to its dealers. While you might not expect the source to be exactly unbiased, it does provide technical information and justification for differences in their formula.
<senders address deleted>
Genuine Honda Coolant is the Only Way to Go -------------------------------------------
Increasingly severe operating conditions and the advent of lower maintenance requirements have resulted in significant changes in the variety and the concentration of additives used in engine coolant. Also, the continual improvements in engine and vehicle design have challenged coolant suppliers to design products that perform well in a more demanding environment.
To meet these needs, Honda engineers have developed a superior, high-quality coolant that has several advantages over the competition.
Some antifreeze, although labeled as safe for aluminum parts, may not be compatible with Acura cooling system components. Extensive research and testing by both Honda R&D and CCI, the manufacturer of the Honda coolant, have proven that the abrasive silicates and/or borates found in most domestic coolants can cause these problems:
- Silicates bond to the surface of the water pump seal and act as an abrasive, causing considerable seal erosion and coolant leakage. In actual tests, the silicated coolant caused early leakage. This leakage increased dramatically until a substantial portion of the coolant had been lost. In contrast, the Honda coolant had almost no leakage through the duration of the test.
Chart here, entitled "Coolant Leakage from Water Pump Seal", showing Leaked Coolant Volume in ml as follows for each test duration in Hours:
24 hrs: Honda Coolant 0, Typical Silicated Coolant 21 48 hrs: Honda Coolant 1, Typical Silicated Coolant 36 72 hrs: Honda Coolant 2, Typical Silicated Coolant 47 96 hrs: Honda Coolant 2, Typical Silicated Coolant 55 120 hrs: Honda Coolant 2.5, Typical Silicated Coolant 56 144 hrs: Honda Coolant 3.5, Typical Silicated Coolant 57 168 hrs: Honda Coolant 4, Typical Silicated Coolant 58.8 192 hrs: Honda Coolant 6, Typical Silicated Coolant 63 200 hrs: Honda Coolant 6, Typical Silicated Coolant 64
- Silicates tend to gel and settle in the coolest parts of the cooling system, causing radiator plugging and overheating.
- Borates cause pitting corrosion on the cylinder head.
- Silicate inhibitors are difficult to stabilize and, therefore, limit coolant shelf life.
Most commercially available coolants were originally designed for cast iron engines. Silicate, an inexpensive additive, was added to coolants to prevent aluminum corrosion, but the long-term durability of the combination was not tested.
In contrast, Honda coolant was designed specifically for aluminum engines. It contains an organic corrosion inhibitor instead of silicate. This superior formula gives these advantages:
- No silicate abrasion of water pump seals. For example, these graphs show the surface roughness of two aluminum water pump seal rings. Seal A, exposed to silicated coolant, shows considerable damage. Seal B, exposed to Honda coolant, displays only minute wear.
(graphs here, showing roughness across the surface, with A a very wiggly line, and B a very smooth line)
- No plugging or overheating caused by silicate gelling.
- Excellent corrosion protection for aluminum components.
- Long-term corrosion protection for other cooling system materials (steel, cast iron, copper, solder, gaskets, seals, and O-rings).
(note from XXX - I think I can guess whether the last paragraph, provided below, was written by the engineers or by the marketers...)
You can find less expensive coolants on the market, but now you can see why genuine Honda coolant is the only coolant approved for Honda and Acura vehicles (it MUST be used for warranty repairs). Honda's non-silicate formula delivers added protection not offered by 95 percent of other brands. Since our customers expect lower maintenance, you're doing them an injustice if you use any other coolant.
Old Nov 8, 2004 | 07:14 AM
larryfs's Avatar
larryfs
and why is that??
that is the entire point of the new formula coolant. "mix with any color"
and that Honda stuff is interesting. My 96 Impala suffered from 5 clogged heater cores from the factory dexcool. hmmmmmmm. maybe time for some Honda Coolant...................
is it readily available? or should I go to a honda dealer.. ?
I don't even know what / who / where a honda dealer is
Old Nov 8, 2004 | 01:04 PM
LT4fun's Avatar
LT4fun
Well I guess they could void the warranty on new Hondas, but if the Honda was still under warranty I would have had them replace the thermostat.
Anyway, it's a '98 Accord with a little over 101,000 miles on it. The radiator looked very clean when I changed the antifreeze, so the Honda coolant looks like it does a very good job.(although I can't be positive it's had honda coolant in it since new, and I know I topped it up last year with non-honda coolant.)
I just wanted to show that the Super Tech extended life antifreeze is made by Prestone(they operate a plant in Alsip, IL), and makes the same exact same claims as the extended life Prestone. I don't see how Prestone could cut corners when making the Super Tech antifreeze and still make the exact same claims when it comes to extended life and compatibility with any kind of antifreeze.
As for using Dexcool, I've had no problems with it. GM's leaky plastic tanks are a different story however.
Thanks for the article, it's an interesting read.
Randall
To new coolant.
