Starter
Old Nov 9, 2004 | 10:55 AM
Sirwilliam1229's Avatar
Sirwilliam1229
Default Starter
When I try to start my vette, it goes clunk at every attempt. After a few trys, it fires right up, and runs great! When I shut it off, it will fire right back up 60% of the time. Let it sit, and we are back to clunk!! . What is going on?
Old Nov 9, 2004 | 11:17 AM
DanS711's Avatar
DanS711
I would start by checking for a loose cable at the starter, loose cable at the battery and then go to the solenoid.
Dan
Old Nov 9, 2004 | 11:18 AM
mikey whipreck's Avatar
mikey whipreck
clunk and no crank? or clunk and continued cranking
could the flywheel be missing some teeth?
Old Nov 9, 2004 | 12:45 PM
88421VETTE's Avatar
88421VETTE
Mine was having the same problem I pulled the wires off the starer cleaned them and it worked fine. Might
88421VETTE's Avatar
88421VETTE
Mine was having the same problem I pulled the wires off the starer cleaned them and it worked fine. Might want to check the battery wires also
Old Nov 9, 2004 | 01:03 PM
vetteweiser's Avatar
vetteweiser
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'13- '14
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
hmm, mine just started doing that too Guess I'll check the cables and what not before replacing the starter.
Old Nov 9, 2004 | 01:48 PM
88421VETTE's Avatar
88421VETTE
I would cause my Vette and both my Irocs did the same thing
Old Nov 10, 2004 | 10:30 AM
darkman5001's Avatar
darkman5001
Sounds to me like your starter's selonoid is going. My vette went through like 3 GM remanufactured starters in the fast 4 years. The problem is that the selonoid overheats by being so close to the exhaust manifolds. Over time, starting WILL get harder. After awhile, you will have to start banging on the starter with a hammer. Eventually, that won't even work. This happened to me for the last time about 6 months ago. After I had the clanging sound for a while, then the starter would start to click like it was the battery, which was a brand new Die Hard, and the fly wheel was changed a few years back. I bought a Summit Racing high torque mini starter for about $150 new. I also bought a heat shield to wrap around the starter to protect it from heat. The starter shield wrapping is an invaluable thing to have, and especially everyone with a vette with headers should have one wrapped around their starter. The new Summit starter I bought only draws 90 amps, and is powerful enough to turn over an engine up to 18:1 compression, so it has no problem what so ever with turning over my L98. Invest in a good mini starter, and absolutly get the heat shield wrapping. The wrapping is only like $25 from Summit. I hope this helps you a little. Good luck.
Scott
Old Nov 14, 2004 | 12:28 AM
Sirwilliam1229
Default Starter
Thanks fellas, this is some very good information!
To Starter
