Header question
Old Nov 9, 2004 | 07:05 PM
bowersock's Avatar
bowersock
St. Jude Donor '05
Default Header question
A few questions for those of you in the know----
On longtube headers where would I weld the O2 sensor bung before coating?
Is there a commercially available kit to block off the EGR system?
Will there be any other problems with "check engine light" or anything?
Thanks Roger
Old Nov 9, 2004 | 07:22 PM
CFI-EFI's Avatar
CFI-EFI
http://forums.corvetteforum.com/showthread.php?t=941292
RACE ON!!!
Old Nov 9, 2004 | 07:26 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Always a good idea to let us know the year and other pertinent info too, since by far, not all C4s are the same!
Old Nov 9, 2004 | 07:44 PM
mikey whipreck's Avatar
mikey whipreck
at the collector, i dunno what year you have so you may hafta do both sides or just one
yes
If you remove the EGR system, yes.
If you only remove the AIR sytem, no.
Old Nov 9, 2004 | 10:20 PM
bowersock's Avatar
bowersock
St. Jude Donor '05
Default headers cont.
What is the air system?
This is for a 86L. DO I need both or one side?
Old Nov 9, 2004 | 10:43 PM
mikey whipreck
For the air pump do a search... I dont know how to explain it well...
To find out if you need one or two, just look at your vette... Do you see an 02 sensor on each side? or only on one side? I don't know late model 86's.
Old Nov 10, 2004 | 07:05 AM
rodj's Avatar
rodj
If '86L = '87 then only one sensor , drivers side
To Header question
