right headlight
Old Nov 10, 2004 | 10:42 PM
El Snoid's Avatar
El Snoid
Default right headlight
on my 85 just yesterday i turned my lgiths off and the right headlight did not move. this was the first time this has happened since i bought it in august. the lights work fine it jsut wont move up and down.any idea what it could be? bad wire? how could i check?
thanks,
Kevin
Old Nov 10, 2004 | 10:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
First listen to see if the motor is running, if not check for +12Vdc on the Red wire into the headlight motor relay on the LH fender well below and to the left of the LH headlight.
If no power on that wire check the fusable link, one of two on the firewall below and to the left of the master cylinder.
If the motor is running, try to move the headlight with the manual ****; does it move the headlight, does it feel firm?
