U joints on left and right half shaft
Old Nov 11, 2004 | 08:29 AM
TheStef's Avatar
TheStef
Default U joints on left and right half shaft
I'll be replacing these this winter, ( just parked the car for winter this week ) I'm just wondering after I change the U joints, if I should have the shafts balanced? I know the main drive shaft can be balanced but I'm not to sure about the half shafts, or if its even worth it.
Thanks!
Old Nov 11, 2004 | 09:08 AM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Unless they were shacking like a wet dog and you could feel it, I would not worry about it.
Old Nov 11, 2004 | 09:56 AM
TheStef's Avatar
TheStef
Well, here's the story, I'll try to make it short.
The car has been making a humming sound (seems to be on the rear driver side) on occasion it even has a slight vibration at highway speeds, but its honestly hard to tell because of the bumps and cracks on the highway.. these might be causing of the occasional vibration.
So far I have changed the rear driver side wheel bearing, the tires in the back (needed to be changed anyway's), I changed the main drive shaft U joints, the humming now seems less present but maybe its just me.
The only thing that are left are the half shaft U joints, the rear passenger side bearing, the two front bearings, 2 front tires (they will need to be changed anyway's), but before I spend the money and the trouble on all of this... maybe someone else had a similar problem and I've been looking/fixing the wrong things.
I made up my mind and will have the half shaft balanced, just in case and for peace of mind.
Thanks!
Ps: I was told fixing/tracking a drive train noise is very hard, I guess its true.... but I'm not a mechanic, so any help is really appreciated.
To U joints on left and right half shaft
