Hooking up a/c & alt brackets with headers??
Old Nov 13, 2004 | 06:11 AM
Nathan Plemons's Avatar
Nathan Plemons
I ran my headers for well over a year without all the braces in place, I never had any troubles, but then my AC didn't exactly work either.
I had heard about the vibration issues when running the A/C so when I fixed the AC I went ahead and installed the braces.
Old Nov 14, 2004 | 05:51 PM
Nathan Plemons
Ok here are the pictures. I included links rather than just posting the pictures because they are very large.
The first picture here is what I like to call bracket #1, it goes from the intake to the alternator and on to the A/C compressor. Bracket number one is supposed to mount in front of bracket #4, the one bracket you have to leave off. As you can see by the arrow I fabricated a spacer to make this work.
http://home.insightbb.com/~nathan.pl...ics/spacer.jpg
Bracket 4 is supposed to go from this header bolt to where my spacer was, the header primary tube doesn't allow this to happen in any way, thus why you have to leave this out.
http://home.insightbb.com/~nathan.pl...s/bracket4.jpg
The last picture here is of brackets 2 & 3. Using the spacer provided by hooker and one of the original manifold studs you can hook them up exactly like they are supposed to go.
http://home.insightbb.com/~nathan.pl...rackets2_3.jpg
I have found that by running 3 out of the 4 original brackets the car doesn't have any vibration issues with the A/C on. I have done this on two different LT1's with the same results, I really couldn't be happier with it.
Old Nov 14, 2004 | 10:15 PM
rodj's Avatar
rodj
Give your L98 a good rev from under the hood and watch the Alt and A/c flex on their mounts.That is why I put my brackets back on.
Old Nov 15, 2004 | 11:33 AM
GlockLT4's Avatar
GlockLT4
Thanks for the pics nathan!!
Old Nov 15, 2004 | 11:47 AM
Perfusion's Avatar
Perfusion
I'll definitely take a copy of 'em to the shop who installed my headers and say, "Do this."
Old Nov 15, 2004 | 11:59 AM
GlockLT4's Avatar
GlockLT4
I could feel it in the entire car when i had mine off on the '94.
Old Nov 15, 2004 | 02:53 PM
Nathan Plemons
I wouldn't have known. When I installed the headers I effectively broke the AC and didn't bother to fix it until I knew I had my oil leaks resolved. While the A/C didn't work I learned of the supposed vibration so I thought it would be a good idea to figure out a way to put it back when I did fix the A/C. I got to looking at the hardware provided and figured out how it was supposed to work.
So as such I've never actually felt the vibration, but I fully well believe it exists. I watched one car that had a supercharger dancing around so much I honestly thought it was going to toss the belt and it was just at IDLE!
Old Nov 15, 2004 | 07:59 PM
Powerdrive's Avatar
Powerdrive
The vibration definatly exists.....I suffered from it last summer. Discovered my brackets were so loose they could be wiggled by hand. Totally dissappeared after getting everything tightened down. Im going to order headers soon and never even considered the brackets a problem.....thnx for the heads up.
Old Nov 15, 2004 | 09:23 PM
silver & red CE's Avatar
silver & red CE
Crap, I'm going to have to put those brackets on...this header install is getting me pi$$ed.
Old Nov 16, 2004 | 12:52 AM
TA's Avatar
TA
Here's the Alternater bracket I fabbed up for my headers. Its 1/2" conduit crimped on the ends and bent to the correct angles. I'll eventually being making a simialr AC bracket.
Old Nov 16, 2004 | 02:20 AM
BAM92's Avatar
BAM92
I guess I got luck with my TPIS headers as they don't even get near to burning my MSD wires and I was able to radius grind factory brackets and reuse factory bolts after also radius grinding their seats. Had to do a little grinding on oil dipstick bracket also.
Old Nov 16, 2004 | 02:22 AM
BAM92's Avatar
BAM92
TA I see you have a line lock in there.
