Idle issue re-visited.
Old Nov 11, 2004 | 11:34 PM
Trog's Avatar
Trog
Default Idle issue re-visited.
Okay I've replaced just about everything now & still have the same issue.
Idle varies between 900 & 1200 RPM when the car is rolling but on occasion when first starting up. Always seems to settle down a minute at most after start up.
When rolling, forward or reverse, a few seconds after the the car comes to a complete stop the idle drops to 800 & stays put.
Example would be rolling up to a stop sign, put the clutch in & the idle does its little game as I'm rolling up. After I stop it might do it one or two more times then settles down.
I've replaced the IAC & the IAC/coolant housing on the bottom of the throttle body. While I had the TB off for that I completely cleaned up all the deposits in both the front/back/top/bottom of the TB & IAC passages. It was "spotless" when I put it back together. No change in the issue.
Same issue with both the stock chip & an after market that I'm now running.
I have the coolant bypassed by the way. Since I bought the new IAC house I even cut the stupid fittings off flush so they don't stick out. If for some crazy reason I need it back I'll have to put the old housing back on.
Does anyone have any ideas?
Old Nov 12, 2004 | 01:20 AM
vettenut85's Avatar
vettenut85
the shafts on the throttle body could be wore and leaking vacumn thru them causing the idle problem. the factory just puts the shafts in with a rubber o ring seal that wears out after a while,then the shaft bores get elongnated.
Old Nov 12, 2004 | 03:23 AM
ClarenceT's Avatar
ClarenceT
What he said, GM TB doesnt have bearings, so the TB wears over time and the holes go oval; then the blades get stuck in part-open position, hence "wild idle syndrome"
I have it too, just don't care atm.
e-mail dkoldos@ameritech.net, he sells rebuilt TBs on e-bay, with bearings installed, and a slew of other mods, good stuff apperantly.
Old Nov 12, 2004 | 08:11 AM
TheStef's Avatar
TheStef
I seem to also be having the same problem, I'm 90% certain its because of the TB as well. I tested the TPS voltage a few months ago and it was fine, but I didn't test the AIC. My symptoms are very much the same, sometimes it will stay stuck between 900 to 1200 rpm when at a stop sign, but it I tap the gas pedal slightly it will go back to down 700rmp.
I also don't' really care at the moment....
Old Nov 12, 2004 | 10:17 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Iv'e learned to live with it. Maybe someday I'll replace the TB or get it machined with bearings.
Old Nov 17, 2004 | 01:43 PM
ClarenceT's Avatar
ClarenceT
Heh, you guys have it easy then haha.. My TB is massively messed up - my idle can go up to 2k.. Again a tap of the gas fixes it, but somewhat annoying while braking (with the motor pulling)
To Idle issue re-visited.
