New Mass Mod
Old Nov 12, 2004 | 12:34 AM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
Default New Mass Mod
My buddy is doing some experimenting on his Vette.
(89 model)
Increasing the air a good bit. What are the problems going to be in this modification?
(anything trigger first in your minds?)
Has he overlooked something here...mainly the manifold pressure.....Possible damage to the engine.
It has 35% more air capacity and the original guts of the stock Mass......would be interested to hear what you guys have to say.
Rain
Old Nov 12, 2004 | 12:37 AM
aeronautica86's Avatar
aeronautica86
there isn't really a problem, but it will not gain him any HP, this is not a restriction in the stock setup
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
(89 model)
Rain
What the hell is that thing??
Old Nov 12, 2004 | 12:40 AM
James94LT1's Avatar
James94LT1
I don't think the stock Maf will be calibrated properly for all increased air flow. Its probably going to require some tuning.
Old Nov 12, 2004 | 01:12 AM
vader86's Avatar
vader86
It should help some on the L98, since the MAF is a slight restriction.
Only problem will be tuning that and getting it to run properly.
Old Nov 12, 2004 | 01:16 AM
96zride's Avatar
96zride
St. Jude Donor '04 &'05
Old Nov 12, 2004 | 01:26 AM
RainJ's Avatar
RainJ
That was my first reaction - tuning to handle the increase.
Will pass these along to him tomorrow -
Rain
Old Nov 12, 2004 | 01:36 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I think the stock MAF will flow more than enough for a stock L98 and a modified MAF will flow to 750cfm which is air than a modified TPI can use.
I'm sure someone here has the equations to correlate cmf with chp.
And, as mentioned, the stock MAF is limited to 255 gm/sec though you could possibly get around this issue by changing tables in the EPROM.
Is the internal diameter 35% larger than that of the stock TPI MAF??
Since it only allows for more air flow, if the sensor wires are stil in the center of the tube, there should be no problems using that setup.
Old Nov 12, 2004 | 02:35 AM
comp's Avatar
comp
are you messin' ?????
Old Nov 12, 2004 | 03:03 AM
ClarenceT's Avatar
ClarenceT
Meter wires have to be in the center - it measures air velocity and knowing the given dia. of the MAF housing the computer calculates total incoming air and directs the injectors to dump appropriate amount of fuel.. Methinks your "friend's" (lol, we know, it's ok!) contraption will run pretty lean...
Old Nov 12, 2004 | 03:13 AM
ClarenceT's Avatar
ClarenceT
Oh, and http://forums.corvetteforum.com/showthread.php?t=946223
Old Nov 12, 2004 | 11:24 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
We love experimenters. As long as they are experimenting on THEIR car!!
Let us know what happens....
Larry
Old Nov 12, 2004 | 12:15 PM
RainJ's Avatar
RainJ
Thanks for the link - passed it on to James.
Keep yall posted (I've not even seen this in person yet, just pics)
Rain
Old Nov 12, 2004 | 12:18 PM
redbullapril23's Avatar
redbullapril23
hahaha
Old Nov 12, 2004 | 12:29 PM
mikey whipreck's Avatar
mikey whipreck
Originally Posted by ClarenceT
Old Nov 12, 2004 | 12:36 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Thanks for making the link to that topic.
THERE IS NOT A RESTRICTION WITH THE MAF
To New Mass Mod
