D44 upgrade?
Old Nov 12, 2004 | 10:23 AM
AS84's Avatar
AS84
Default D44 upgrade?
This winter I am changing the ring and pinion in my 90 6 speed car. I am debating on whether or not buying different output shafts or having mine cryoed. I need something to handle the abuse of 500 rwhp and 26x10 et drags. I am already planning on upgrading halfshafts. What do the guys going fast have done.
Old Nov 12, 2004 | 10:31 AM
Corvette0096's Avatar
Corvette0096
With a 6 speed and that kind of HP you better throw the best of the best at it. What are you doing for 60' Now?
Old Nov 12, 2004 | 06:56 PM
AS84's Avatar
AS84
1.9's with a single plane efi 219 cammed 350 with a 3.33. I would like to see some 1.5's out of my new motor. I would really like to do it "right" the first time
Old Nov 12, 2004 | 09:09 PM
redbullapril23's Avatar
redbullapril23
what gear ratio you have now?
Old Nov 12, 2004 | 10:54 PM
AS84's Avatar
AS84
Old Nov 12, 2004 | 10:59 PM
redbullapril23
what are you doing with old gears??? they are welcome here.
Old Nov 12, 2004 | 11:40 PM
bogus's Avatar
bogus
those gears won't fit in a D36.
Old Nov 13, 2004 | 12:53 AM
redbullapril23
hahaha i think u think im a moron...
im planning on getting a dana 44 from a salvage yard here in ga and its 3.07..cheapest, and 3.33 would be an upgrade.
thanks
Sean
Old Nov 13, 2004 | 10:30 AM
AS84's Avatar
AS84
They will be for sale. I'll have to take them out before I can come up with an asking price though. They don't whine or anything, but they do have 103,000 on them.
Nobody has any suggestions on building a stronger D44?.
My thoughts:
Cryoed case and output shafts
Dana gears
nitrous ready 1/2 shafts
Old Nov 13, 2004 | 10:46 AM
Corvette0096
The only bad thing about a stick car is they don't put any load on the drive train. Build it the best way that you can. I would leave the halfshafts as the week link. You should still be able to do your 1.5x 60'
Old Nov 13, 2004 | 11:57 AM
redbullapril23
for the strongest dana 44,
get viper gears 3.91. then have the inside grinded down a bit and the chuck a little bit too and they will fit. they are a whole lot thinker. then get them cryoed. also get the housing cryoed as well. and then get a master install kit and change out all the bearings and stuff!
I can cryo for you, since im a supporting vendor.
ring and pinion on $110.
let me know!
thanks alot
your friend
Sean Blanton
Old Nov 13, 2004 | 02:13 PM
bogus's Avatar
bogus
thanks
Sean
no, didn't think that... just didn't know you were getting a D44.
There is a lot of misinformation, or, generally confused information, that gets things mixed up at times... just clarifying a point.
Old Nov 13, 2004 | 04:17 PM
AS84's Avatar
AS84
how weak are the input and output shafts? Are these common parts to fail?
Old Nov 13, 2004 | 05:22 PM
redbullapril23
got yas.
To D44 upgrade?
