c5 rear is c4?
Old Nov 13, 2004 | 05:35 PM
redbullapril23's Avatar
redbullapril23
Default c5 rear is c4?
this is probally a stupid question beacuse the c5 is wider. but would it be possile and practicle to put a c5 rear end in a c4? also what kind of diff do they have? dana 44?
thanks alot your friend
Sean
Old Nov 13, 2004 | 06:00 PM
Zix's Avatar
Zix
Sean
Highly doubtful considering the C5's have rear-mounted transmissions.
Old Nov 13, 2004 | 06:10 PM
redbullapril23
haha ok thanks
Old Nov 13, 2004 | 06:18 PM
bogus's Avatar
bogus
anything is possible with sufficient amounts of welding... and it will take a lot of welding... did I mention lots of welding? Copious amounts, actually.
Old Nov 13, 2004 | 08:32 PM
CFI-EFI's Avatar
CFI-EFI
All you'll need is a longer shift cable for your auto trans. It should be an all afternoon job.
RACE ON!!!
Old Nov 13, 2004 | 08:37 PM
redbullapril23
well what kind of rear is it?
thanks alot
your friend
Sean
Old Nov 13, 2004 | 09:43 PM
Trog's Avatar
Trog
Its a transaxle... you would have to fabricate all the mounts... a TON of work but like bogus said... could be done but you better have access to a welder & a torch. Perhaps a whole C5 rear clip to take parts & measurements from.
Old Nov 14, 2004 | 01:45 AM
redbullapril23
oh ok so def not worth it man jsut have to save up for the Dana 44
thanks alot!!!
To c5 rear is c4?
