From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
LT4 spring coil bind height?
Anyone know it? I've found this spec for aftermarket springs but can't seem to for these. I know the safety margin I need at max lift but would really like this spec if anyone has it. Trying to make some new valvetrain set-up decisions.
The spec I'm looking for is the compressed height of the spring when/where bind actually occurs. Example, an aftermarket spring might list it at say, 1.15.
I am going from 7 year old memory so don't hold me to these numbers. The installed height is 1.780. The max lift is .525. This leaves 1.255. If I remember correctly this left about .060 before the spring stacked solid at about 1.195
Originally Posted by silver & red CE
I just measured one off my 96, it's at ~1.200"
That's pretty close because the way I've got it figured it would have to be in the ~1.190 range to have the generally considered safe margin w/ the hot cam. And your numbers are exactly the ones I've been using too, Pete K.
It's hard to measure the crush without wasting the springs. I don't care if GM says it's OK, I wouldn't use LT4 springs on an LT4 HOT cam. I'm dumping the springs with a stock LT4 cam, I just don't trust them, IMHO the pressure's too low and the cast retainers are weak.
That's what I'm thinking now too. I ran them before but with stock valves. Now, with the added weight of larger valves, they're making me nervous. Any recommendations? Comp Cams has a couple of numbers that look promising but I don't yet know if any machining is required. They both have a bind height of 1.15 which would make me much happier and allow for future growth, even!
there's the crane 99846 spring, I've never been able to find spring cups for these. there's also the crane set for lt1 aluminum heads, costs ~$150. Both don't need machining.
To answer my own original question, the LT4 spring bind spec is 1.22. Not good if installed at factory height of 1.78 and running a Hot Cam at .525 lift. Only a .035 margin to bind! So they're history and the search continues for a suitable, affordable replacement.
Here's the lowest cost LT1 aluminum head compatiable springs I am aware of (with no machining required):
Chevy LT-1, 92-99 w/Aluminum Head
270-10308-1 Spring & Retainer Kit $147.99
The Crane part number is 10308
Those look very suitable. One thing's a little strange though, on Crane's site, they are listed as 120# & 312# @ 1.875 installed height while at Summit they're shown at 165# & 426# @ 1.75 installed height. I cannot find a bind spec but one of the cams that Crane shows them for has .518 lift on the exhaust w/ 1.5 rockers and states that 1.6s can also be used so I don't think there's any problem there, especially since they're a dual spring. I think I'd opt for the taller installed height, it still seems like plenty of pressure. Or maybe somewhere in between like 1.8 or so? How critical is valve weight? I'm now using 2.02 Ferrea valves but don't have a way to weigh them compared to the stock ones.
I'd get the beehive ovates w/steel retainers, cost ~$70 over the Crane 10308 kit. I like damperless single springs because there's no heating (ie HP loss) from the friction. Since we're running cams like the HOT/CC305, we don't really need dual or dampered springs. If possible, single damper-less are always the best route.
The Ti retainers are not required, esp with HOT/CC305 cams, I just got 'em 'cause it's my Vette (and it's a $120 insurance policy)
So you're saying the beehives will work with stock retainers for now? I would just need the cup seats then to go with them, right?
