4+3 and better shift linkage
Old Nov 14, 2004 | 01:54 PM
DSKRALL's Avatar
DSKRALL
Default 4+3 and better shift linkage
Does any company make an improved shift linkage for the 4+3 that retains the stock shifter so that the interior of the car looks original? If so, is the linkage a big improvement?
By the way, is the little short throw kit that is sold by ZIP and Mid-America a good idea, or does it eventually cause problems?
Old Nov 14, 2004 | 02:30 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
No. Any other shifters would require some fabrication.
The short shift kit helps, but don't buy into the false advertsizing on how much it shortens the throw.
Hell, the links weren't even bolt-on parts. The rectangular hole was sloppy, and they would slip on the shifter shafts, completely f'ing up my neutral alignment and making it impossible to get into 3rd & 4th gear.
I took em back out and beat on them with a ball peen hammer to shrink the hole down till it fit snug... haven't had a problem since.
Old Nov 14, 2004 | 02:48 PM
DSKRALL's Avatar
DSKRALL
Thank you. Is there any method for making the stock set-up work better? It's okay as it is, but if there is room for improvement by adjusting it or lubricating it I would be happy to learn.
Old Nov 14, 2004 | 02:55 PM
CentralCoaster
I pulled mine apart, cleaned it and tightened it up by putting a shim in to clamp the shifter plates closer together. Also put it in a press, but I'm not sure if that did much.
Also, along with the shift links, adjusted the neutral alignment VERY exactingly, by feel, so the shifter movement is as smooth as it's gonna get. It's 100% better than before, but still a crappy design. You can't polish a turd.
Old Nov 14, 2004 | 03:53 PM
88BlackZ-51's Avatar
88BlackZ-51
i dont find it that bad.....
Old Nov 14, 2004 | 04:12 PM
Curveit's Avatar
Curveit
I installed the short-shift kit years ago...no problems with fit, or use. I think it shortened the throw by about 1/2. I like it just fine, but you may need to check your alignment with installation.
Old Nov 14, 2004 | 04:46 PM
LD85's Avatar
LD85
I have some of the short throw linkage if you want to PM or email me,
I think it was noticeable improvement,, its your only cheap option really
Old Nov 14, 2004 | 06:00 PM
XQIZT's Avatar
XQIZT
i have the short shift kit...it is a sloppy cut part because they drill the holes BEFORE they stamp the part i think it does a real good job of shortening the shifts. when i am pounding through the gears, i don't miss nearly as much. that grinding sound it awful. and its only $20. what other "performance" parts will you find for a vette for that price?
Old Nov 14, 2004 | 09:23 PM
Dominic Sorresso's Avatar
Dominic Sorresso
I bought something that made the shifting INCREDIBLY better. The part number is ZF-6.
Old Nov 14, 2004 | 09:34 PM
CentralCoaster
It's not that bad, just not good enough. There's commuter cars with shorter shift throws than the vette.
Old Nov 15, 2004 | 05:26 PM
DSKRALL's Avatar
DSKRALL
Thanks for the replies. A properly adjusted stock linkage is probably the easiest route to take.
To 4+3 and better shift linkage
